Author Topic: advance mechanism leak - how hard to repair?  (Read 2192 times)
July 25, 2011, 09:39:17 am
derekp
  • 94
« on: July 25, 2011, 09:39:17 am »
my 92 jetta seems to be leaking fuel where the advance mechanism goes into the pump body.
I cant see it too well - dont know if theres other things on that side of the pump that can leak. (I'll be looking at a junk pump I have at home to see what else is on that side of the pump)
I wonder if anyone can tell me how hard it is to replace the seal/gasket that the advance mechanism needs?
Also - where can I get the appropriate seals/seal kit to do this repair with.
thanks!
The fleet
92 eco diesel (my driver turned project)
94 suburban (mine)
69 Chevelle 327 w/hillborn - resting nicely
89 Jetta coupe (sons 16v ABA head swap w/turbo and megasquirt - not run yet)
2000 jetta (other sons)
98 jetta (daughters)
2001 jetta tdi (girlfriends)
03 subaru outback (girlfrie
Reply #1July 25, 2011, 12:29:13 pm
  • 4553
Re: advance mechanism leak - how hard to repair?
« Reply #1 on: July 25, 2011, 12:29:13 pm »
Fix is easy to do.  A couple of O rings. One on the shaft and one in the cover if I remember right.  If that is all you need you might find them at an auto parts place.  Just have to be able to take the diesel fuel.  I did a complete rebuild so I got the entire 30 dollar kit and the rings were in that bunch.  If I only needed the two I would be shopping around.  Diesel truck repair shops?
