Author Topic: 1.9L TD AAZ into a 2.slow shell (SWAP) - MK3  (Read 8700 times)
Reply #15September 13, 2011, 02:04:01 pm
Golf/Jetta
  • 102
Re: 1.9L TD AAZ into a 2.slow shell (SWAP) - MK3
« Reply #15 on: September 13, 2011, 02:04:01 pm »
I read up on the oil pressure switches on Vince Waldons web site, kinda interesting that you really don't need a computer to you that you have a pressure problem. With two led light hooked up in the dash using the oil pressure switches; The low pressure switch should stay turned off when the engine is running and; the high pressure switch should turn on or about to turn on.
I'm able to play with my smoke screw as the pump is pre-modded thanks to the previous owner and I can turn it all the way in if I wanted to (collar is missing).
With the engine off and my volt meter, I tested the low pressure switch and there is a connection to ground. I tested the high side and nothing.
With the engine on, I tested the low pressure switch and nothing. I tested the high pressure switch and there is a connection to ground.
I then turn the smoke screw down below idle point (car violently shaking) and the high pressure switch started fluctuating on, off, on, off, etc. I kept turning the smoke screw down a bit and the pressure switch turned off. Turning the smoke screw back up past the high pressure switch fluctuating point, it switched back on.
This was done after a 10 min hard driving as i'm actually trying break something.
« Last Edit: September 13, 2011, 07:45:39 pm by Golf/Jetta »
'97 Jetta - 4Dr - 1.9 TiDi (Forth Car)
'94 Jetta - 4Dr - 2.0L Swaped in an AZZ - Almost done 2011 b4 Winter (Third Car)
Blue '87 Golf - 2Dr - Tags (First Car)
Red '92 Jetta (W) - 4Dr - Sold to Friend For $200 (Second Car)
Thanx For Answering My Posted Question's/Comments...
