Author Topic: Finally, Rosten has made 1.6TD H-beam rods!  (Read 2888 times)
July 18, 2011, 04:18:30 am
Alcaid
  • 549
« on: July 18, 2011, 04:18:30 am »
Finally, a trusted vendor supplies H-beam rods for our 1.6TD builds at a decent price!
If you're not familiar with Rosten-Performance, check out the TDIClub forums.
 - 136mm center - center
 - 24mm small end with bronze bushing
 - 50.6mm big end
 - 2 piece forged from 40CrNiMo steel
 - comes with ARP 2000 bolts and assembly instructions
 - shoot peened and heat treated
 - weight is 560 gram included bolts, with a tolerance of +- 1gram
 - Designed to use TDI rod bearings which are far better than the 1.6TD
 - Price complete set: 350.00 €
www.rosten-performance.com
I'm in no way affiliated with this vendor, just giving you guys a heads up :)
'10 VW Passat 1.6TDI Highline
Reply #1July 18, 2011, 12:25:24 pm
MJF
  • 581
Re: Finally, Rosten has made 1.6TD H-beam rods!
« Reply #1 on: July 18, 2011, 12:25:24 pm »
Thanks, good to know 8)
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #2July 18, 2011, 10:41:02 pm
cyrus #1
  • 360
« Reply #2 on: July 18, 2011, 10:41:02 pm »
I have been waiting for these to appear. Thanks for posting. Hopefully these won't just be a limited run item.
Cody
2002 Jetta TDI
2000 Jetta TDI - R.I.P.
Reply #3July 19, 2011, 10:40:17 am
truckinwagen
  • 1895
« Reply #3 on: July 19, 2011, 10:40:17 am »
had to be after I quit driving a VW...
oh well, good to see that they are being made at last!
-Owen
83 Opel Kadett Diesel
