Author Topic: overheating  (Read 2082 times)
July 13, 2011, 07:45:54 pm
alexgingles
overheating
« on: July 13, 2011, 07:45:54 pm »
'91 ecodiesel with a MF motor.  I replaced the water pump and thermostat this week and installed a block heater.  My car now overheats.  My radiator is cold, my hoses and engine are hot and the needle is almost pegged.   I thought it was the thermostat so I removed it.  I boiled some water and it opened up at 160F.  I then buttoned everything up MINUS the thermostat.  Without the thermostat, I am still overheating in the same manor.
I installed a Graf brand waterpump.  Has anyone had problems with these?  Seemed like a solid part when I installed it.  I'm going to pull the hoses off tomorrow and back flush the radiator to see if there is maybe a clog.  I didn't have an overheating problem before I installed these.
Am I missing anything?  Thanks for your help!
Reply #1July 13, 2011, 08:20:48 pm
Baron VonZeppelin
Re: overheating
« Reply #1 on: July 13, 2011, 08:20:48 pm »
What a kick in the arse !
Would either have to be a huge air pocket in the system (but refilling it without a t'stat "should" have eliminated that possibility).
Or the impeller on the new pump is defect / made wrong / wrong impeller installed during manufacture / or slipping spinning on shaft.
Or the radiator is suddenly clogged.
Do you have the belt on the pump pulley - and tensioned (don't cuss me just covering the bases)
Have you run it with the expansion cap off just to see if it would purge any air - and is there a good flow going to the expansion tank ?
They used a restrictor/anti-backflow valve in the hose going to the expansion tank on a lot of mk2's. If its clogged - it could cause some probs - like not letting trapped air purge into the expansion tank.
I'm not familiar with Graf brand.
Reply #2July 14, 2011, 02:57:41 pm
Re: overheating
« Reply #2 on: July 14, 2011, 02:57:41 pm »
You definitely need a thermostat installed with these engines... when the thermostat opens it also blocks off the radiator bypass, so no 'stat, wide open bypass.
Reply #3July 14, 2011, 08:17:17 pm
alexgingles
Re: overheating
« Reply #3 on: July 14, 2011, 08:17:17 pm »
Zeppelin, I think the radiator was suddenly clogged.  I removed the upper radiator and started the car.  Coolant flowed out so the pump was definitely pumping.  I shut the engine off and took a garden hose and black flushed the cooling system for about 10 minutes.  I then buttoned it back together and topped it off with water.  Doesn't get past halfway now.
Tomorrow I will drain the water, reinstall the thermostat and put in coolant and hopefully the problem doesn't resurface.
Good to know there is a check valve in the small hose to the coolant reservoir.
Thanks for everyone's help!
