Author Topic: Try to start Frankenmotor for the first time.....  (Read 13800 times)
Reply #45July 22, 2011, 03:16:16 am
Mark(The Miser)UK
  • 1557
Re: Try to start Frankenmotor for the first time.....
« Reply #45 on: July 22, 2011, 03:16:16 am »
Someone check that smokey garage over there for bodies will ya?
I bet he's gone and started it up  with the g/b in reverse, and collapsed his garage, or worse still...
http://www.straitstimes.com/BreakingNews/World/Story/STIStory_693479.html
Mark-The-Miser-UK
Reply #46July 22, 2011, 03:35:52 am
regcheeseman
  • 714
« Reply #46 on: July 22, 2011, 03:35:52 am »
COUGH
COUGH
HACK
COUGH
(spits black tar)
COUGH
COUGH.....
Well it runs. you've heard the phrase blowing coal?
A young petrol head golf owner had come round to buy some seats, but he was interested to see it run up, he was in for a shock.
This is how it went....
went for run three last night.... it bled up fairly quick, then showed 0 sign of life because the bleed bolt was loose on the head.
Bolt tightened I try again, it fired, spluttered a bit then took off, RUNAWAY!
I pulled the plug and escaped before the thick black cloud came down again. It was a good ten minutes before you could see the back of the garage again.
Backed the fuel screw down 2 turns and tried again
It didn't want to go, then I noticed the aux tank had been slurped dry, I topped it up and went again....
It fired up after a few seconds cranking and settled into a highish idle. I stopped the motor, disconnected the aux tank and switched to the main tank feed. The pump was sucking the aux tank dry in a matter of seconds.
Fired up again and there was a bit of splutter as the main diesel came on. then smooth idle about 1300 rpm :)
I tried to get the the idle down and ran out of adjustment.
Revving the motor produces huge clouds of thick black death, so maybe the fuel is a little high still! But boy does it want to rev. :)
There's no turbo at the moment, I can't fit the inlet manifold until the clutch master turns up and I can get that fitted.
I'll get the turbo/interrcooler pipework fitted up soon and back down the pump (timing and fuel delivery)
Then get a video....
Reply #47July 22, 2011, 10:00:09 am
regcheeseman
  • 714
« Reply #47 on: July 22, 2011, 10:00:09 am »
Brum brum.
Reply #48July 22, 2011, 07:46:25 pm
lovinthedeez
  • 489
« Reply #48 on: July 22, 2011, 07:46:25 pm »
sounds awesome.   ;D  good job
Reply #49July 22, 2011, 09:17:50 pm
  • 4553
« Reply #49 on: July 22, 2011, 09:17:50 pm »
The new TERROR of North Devon.  Does have a hearty pull to it.  Keep adjusting once you get the rest on and running.  I fear for the small children and dogs in the neighborhood.
Reply #50July 25, 2011, 02:15:23 am
Mark(The Miser)UK
  • 1557
« Reply #50 on: July 25, 2011, 02:15:23 am »
Great stuff, but  I look forward to hearing it withthe manifolds and exhaust on. Probably sound like a kitten ;D
When my exhaust sheared off at the turbo, going through Worcester in a traffic jam was interesting. At idle it was just a loud old car but as soon as I loaded it, the turbo would pick up and it sounded like a jet warming up. Very embarassing, except when I was behind a young racer with his GTI revving up. Then he could only look in the mirror and wonder  8)
Mark-The-Miser-UK
Reply #51July 25, 2011, 03:39:16 am
regcheeseman
  • 714
« Reply #51 on: July 25, 2011, 03:39:16 am »
Do you have a kitten that likes to hammer violently?
I've played with the timing last night, finally settling on 1.15 mm advance.
(Just to recap - GTD/1Y hybrid with AAZ pump and 10mm TDI pumphead.)
Any less and the engine would start to smoke a bit white and splutter a bit, more and the clatter is worse.
As it stands now, it starts easy, runs clean and the only reluctance is a slight misfire if you give it too much throttle when the motor is cold.
Once it's up to temperature it's fine. Hopefully this will be the same once under load.
Reply #52July 25, 2011, 05:01:05 am
Mark(The Miser)UK
  • 1557
« Reply #52 on: July 25, 2011, 05:01:05 am »
What injectors? Break pressures?
Mark-The-Miser-UK
Reply #53July 25, 2011, 09:28:53 am
regcheeseman
  • 714
« Reply #53 on: July 25, 2011, 09:28:53 am »
possibly 1Y or AAZ injectors set at 155 BAR
