Author Topic: Fuel pump  (Read 4215 times)
July 12, 2011, 08:55:17 am
silentdub
  • 135
Fuel pump
« on: July 12, 2011, 08:55:17 am »
I read on several posts how people keep their Petrol Fuel pump for one of two reasons.
1. The IDI pump is weak and needs a boost.
2. They put a switch in to make priming easy when they run out of fuel.
As some of you know from my other posts, I am dropping a 1.6 in to a 90 jetta. am I able to keep the fuel pump in place, or should I add a switch just to prime it?
I am not sure what the benefits are for adding one.
Reply #1July 12, 2011, 10:21:03 am
Re: Fuel pump
« Reply #1 on: July 12, 2011, 10:21:03 am »
I've always wondered if you could use a stock VW carburated mechanical fuel pump as a supply pump for the diesel. The engine block even has a place where a fuel pump would bolt up. I forget if there is anything underneath it to actually drive the pump.
Reply #2July 12, 2011, 11:40:56 am
Patrick
  • 1034
Re: Fuel pump
« Reply #2 on: July 12, 2011, 11:40:56 am »
I put a diesel in a '92 gas jetta at the end of march. eliminated the pump outside teh tank and hooked everything up. Car ran fine, but was running out of fuel with 3/8 of a tank left. Wired the pump in the tank to go live with the key, been fine ever since. Other option is to remove the pump in the tank. I just found the right wire on the back of the fuse panel (I believe it's red/yellow in the plug off the harness from the tank, but check A2 resource)  cut it off that plug, put a male spade on it, and plugged it in the front of the panel in a spot that went live with the key. Works like a charm. Might actually advance my timing a little, I'm not sure. Runs great, and easy to prime! Be careful, it WILL push major amounts of fuel out of the line under the hoof if it's not connected and the key is on. Return line has no problem handling excess fuel.
Reply #3July 12, 2011, 01:49:03 pm
J Z
  • 42
    Sweden
Re: Fuel pump
« Reply #3 on: July 12, 2011, 01:49:03 pm »
Maybe I just had bad luck with petrol pumps...  ???
I have tried using 2 different petrol intank pumps, but they have stopt working after a few weeks.
Now I use a diesel pump from BMW 525 and it works great.
Plugged red/yellow in with the taillights.
'75 Volvo 242 D24 TIC
'90 Golf II 1,9 GTD
'91 Golf II 1,9 M-TDI
Reply #4July 12, 2011, 03:54:11 pm
JGWarner
  • 77
Re: Fuel pump
« Reply #4 on: July 12, 2011, 03:54:11 pm »
I am back on the fence about this with my TD Fox project. Should I bother trying to find a fuel pressure regulator for diesel? It seems like it would be simpler and easier and cheaper to just delete the in tank pump all together.
Reply #5July 13, 2011, 06:41:12 am
silentdub
  • 135
Re: Fuel pump
« Reply #5 on: July 13, 2011, 06:41:12 am »
I plan on having the pump rebuilt, so I may just keep factory fuel pump and wire it up on a switch, if it works without it, then great, otherwise I can kick it on.
I understand that the IDI pump on the MK1 is all you need unless the pump gets weak over time. Some people I heard add an electric pump when their IDI pump gets weak.
I guess I can try it either way and see the difference.
Reply #6July 13, 2011, 10:58:40 am
keaton
  • 90
Re: Fuel pump
« Reply #6 on: July 13, 2011, 10:58:40 am »
I have been thinking the same think. i was going to make a thread about it at one point but never did......
i don't see why it would not work... its a medium/low volume, low pressure pump that runs off the intermediate shaft.
a gas pump would piss off the IP timing advance, blow seals and return lines off of it, as most gas Fuel injection pumps run 65+psi
FWIW, the Cummins (6BT/4BT) has a mechanical lift pump, iirc it pulls the fuel through the fuel filter(s) and feed it to the IP
2006 1.9L BRM 5-speed Manual... 100% Stock :(
Standalone VGT/VNT controller: http://dmn.kuulalaakeri.org/vnt-lda/
My CAN Bus video recorder: http://www.youtube.com/watch?v=2QuRBQzGs-c
Reply #7July 13, 2011, 11:07:41 am
Re: Fuel pump
« Reply #7 on: July 13, 2011, 11:07:41 am »
there used to be a diesel specific mechanical lift pump.. NLA..
Reply #8July 13, 2011, 12:16:43 pm
mtrans
  • 308
Re: Fuel pump
« Reply #8 on: July 13, 2011, 12:16:43 pm »
By me yes.no VW,it`s only mehanical conections.I use petrol membrane also.
I`ll improve my English
Reply #9July 13, 2011, 12:45:15 pm
keaton
  • 90
Re: Fuel pump
« Reply #9 on: July 13, 2011, 12:45:15 pm »
huh?
i think what you are saying is VW says no. you say yes you can and your using a gas(petrol) membrane pump with out any issue
correct?
Reply #10July 13, 2011, 02:20:07 pm
Re: Fuel pump
« Reply #10 on: July 13, 2011, 02:20:07 pm »
theres only a drive cam on the older IM shafts..
Reply #11July 13, 2011, 08:30:13 pm
Re: Fuel pump
« Reply #11 on: July 13, 2011, 08:30:13 pm »
I just pulled the oil pan on my '92 golf and it does indeed have a lobe on the IM shaft.
Somewhere I have an old diagram of vw's diesel fuel system and it does include a mechanical fuel pump. It was wasn't needed hence the reason it's not used.
To the OP, you don't need an in tank pump unless you plan on running out of fuel often. It's also been proven that it doesn't change the timing at all.
It's all on the forum somewhere..........
Reply #12July 14, 2011, 08:47:00 am
silentdub
  • 135
Re: Fuel pump
« Reply #12 on: July 14, 2011, 08:47:00 am »
Thanks man. I always run my tank on E, it is something that I just do, so I'll keep the pump in place and just wire a switch to it should I ever need to prime it.
Reply #13July 14, 2011, 12:32:55 pm
mtrans
  • 308
Re: Fuel pump
« Reply #13 on: July 14, 2011, 12:32:55 pm »
huh?
correct?
[/quote]
Sorry, it`s not VW, it`s Fiat
