General Information
Troubleshooting
flashing glow plug light ???
Topic: flashing glow plug light ??? (Read 3840 times)
July 06, 2011, 04:56:57 pm
stewardc
July 06, 2011, 04:56:57 pm »
I changed the transmission in my Mk 1 Caddy today. Now, the glow plug light flashes eratically while driving. It started out very rarely, but is now doing it quite a bit.
Any ideas ?
July 06, 2011, 08:08:03 pm
Moderator
4552
Re: flashing glow plug light ???
July 06, 2011, 08:08:03 pm »
How about the ground strap between the battery and the frame and then the one to the engine and or transmission? That is the only thing I can think of. Leaving the wire off the sensor does different things.
July 07, 2011, 04:54:54 am
stewardc
July 07, 2011, 04:54:54 am »
It was the ground alright. The new transmission was all nicely painted and this must have insulated the ground. We moved the ground to the engine block this morning, and no more problems. The voltage gauge on the dash even reads a volt higher...
July 07, 2011, 08:21:40 am
Moderator
4552
July 07, 2011, 08:21:40 am »
Good Deal, Seems like VW's have a blinking light warning system the engineers never designed. When things like this happen the code should always be check grounds. If they only knew.
General Information
Troubleshooting
