Author Topic: No power off idle 1.6TD  (Read 2448 times)
July 04, 2011, 07:42:26 am
dieselherb1
  • 354
« on: July 04, 2011, 07:42:26 am »
Just replaced head gasket(milled head) installed GT15 turbo(spools quicker) Thought I had the timing right(.030) but smokes alot at idle and you have to rev the engine to move the Caddy or engine stalls. Can the timing still be off that much? Or why else?
Reply #1July 04, 2011, 07:57:49 am
Re: No power off idle 1.6TD
« Reply #1 on: July 04, 2011, 07:57:49 am »
You have it timed to .030"? That's way low..
That is 0.762 millimeters, and that is at least 0.12 mm to low from the lowest stock setting.
Re time the motor to at least 0.037" and your problems will be solved, for a little more performance with the exception of more NOX (who cares ;)) you could bump the timing up to 0.040-0.041" :D
Reply #2July 04, 2011, 10:44:36 am
wdkingery
  • 494
« Reply #2 on: July 04, 2011, 10:44:36 am »
This
Reply #3July 05, 2011, 09:04:44 am
rodpaslow
  • 670
« Reply #3 on: July 05, 2011, 09:04:44 am »
Problems with not enough fuel getting to the Inj pump will do the same thing..
Reply #4July 05, 2011, 08:01:23 pm
« Reply #4 on: July 05, 2011, 08:01:23 pm »
When timed properly, yes it could be a culprit.. But the fact that he has stated it is timed to 0.030" is the problem. The timing is very retarded, I'm actually surprised its running so low!
Reply #5July 05, 2011, 08:36:37 pm
vanagonturbo
  • 639
    • Fine Tuning
« Reply #5 on: July 05, 2011, 08:36:37 pm »
Agreed on the timing.
As an aside, why are we talking inches when we are talking timing? Is it common for people to use sillymeasurement on this board?
Reply #6July 06, 2011, 04:37:06 am
« Reply #6 on: July 06, 2011, 04:37:06 am »
I'm Canadian, yet I still have an Imperial gauge LOL
