Author Topic: Headgasket Questions  (Read 6279 times)
June 29, 2011, 12:35:49 pm
« on: June 29, 2011, 12:35:49 pm »
So my brother just texted me at work saying he's got oily substance in his coolant over flow of his 1.6 hydro td.. So we assume HG at this point. I want to put an AAZ metal gasket on it with some head studs as well... Is there any particular gasket I am looking for??
Reply #1June 29, 2011, 12:40:13 pm
Re: Headgasket Questions
« Reply #1 on: June 29, 2011, 12:40:13 pm »
Eliminate the oil leak/cooler.
Reply #2June 29, 2011, 12:46:17 pm
« Reply #2 on: June 29, 2011, 12:46:17 pm »
Ok if I take that out of the equation.. Flush the coolant and see what happens?
Reply #3June 29, 2011, 12:47:59 pm
« Reply #3 on: June 29, 2011, 12:47:59 pm »
Myke W is where I got mine. He sold out though so I don't know where to get them. The aaz metal gasket the right thickness is all you need if you oil cooler checks out.
Reply #4June 29, 2011, 12:55:27 pm
« Reply #4 on: June 29, 2011, 12:55:27 pm »
yea, oil cooler is more common than h/g... easier and cheaper to replace too..
Reply #5June 29, 2011, 12:57:49 pm
« Reply #5 on: June 29, 2011, 12:57:49 pm »
K got my bro tearing in to it right now. Told him to take the two coolant lines off the cooler, and stick them together. And cap off the two ports on the oil cooler.
Take the rad out and flush it, and flush the motor with the hose and light detergent. We'll see what happens I guess.
Thanks a bunch guys!
Reply #6June 29, 2011, 05:27:31 pm
vanagonturbo
  • 639
    • Fine Tuning
« Reply #6 on: June 29, 2011, 05:27:31 pm »
you might want to have him leave those caps off the oil cooler and verify its the culprit...
Reply #7June 29, 2011, 05:48:33 pm
« Reply #7 on: June 29, 2011, 05:48:33 pm »
yup, cause oil will leak out the cooler eventually..
and you can avoid the connecting the 2 hoses together if you simply use some n/a hoses that do not have the oil cooler connections..
Reply #8June 29, 2011, 08:11:37 pm
damac
  • 531
« Reply #8 on: June 29, 2011, 08:11:37 pm »
Curious because I noticed some stuff in my coolant reservoir recently and wondering if we are seeing the same thing.
Months ago I flushed everything and installed new seals and water pump, thermostat and coolant.  Got new hoses as well.
Everything seems fine performance and fluid wise but I have what I would call black sand type particles that are collecting down low in the reservoir.  But I have never detected an oil slick at the top of the fluid even after settling, and its all still pink.
I thought maybe some bits were leftover on my new hoses and just slowly circulate and collect there, is that normal and maybe we have the same thing going on?
1985 turbo diesel jetta
Reply #9June 29, 2011, 08:20:22 pm
vanagonturbo
  • 639
    • Fine Tuning
« Reply #9 on: June 29, 2011, 08:20:22 pm »
do you have a factory oil cooler of unknown age?
Reply #10June 29, 2011, 09:42:30 pm
damac
  • 531
« Reply #10 on: June 29, 2011, 09:42:30 pm »
Mine looks like an old part, I just replace the oring and gasket when I had all my stuff off cleaning.
Hmmm thanks for this thread as a reminder, I am going to dump my coolant and blindly replace this part.  Does anybody have any issue with the cheap replacement parts they make now, or this is something I should specifically get from vw?
I assume they corrode inside like a heater core and mix on the inside where you can't service it?
On my old f250, that thing has a huge external oil cooler and it has 4 orings you replace.  When I brought the truck home oil was puking into the coolant reservoir and ruined all the hoses, etc.
Reply #11June 30, 2011, 05:29:27 pm
clarkrep
  • 117
« Reply #11 on: June 30, 2011, 05:29:27 pm »
You might check out thesamba for a new old stock one.
Seems I saw one on there less than a week ago but I didn't find anything besides a used one in my quick search.
I don't have any experience with the aftermarket ones.
'79 Rabbit Diesel L 1.5
'83 Rabbit GTI 1.6TD
Reply #12June 30, 2011, 05:35:37 pm
Luckypabst
  • 502
« Reply #12 on: June 30, 2011, 05:35:37 pm »
If it is the headgasket, Partgeek had them for a great price. However, a MLS gasket isn't worth the hassle on even a mildly modified engine.
Chris
'82 TD Westy
'81 NA Caddy
Reply #13June 30, 2011, 06:48:23 pm
« Reply #13 on: June 30, 2011, 06:48:23 pm »
Not worth the hassle? Please explain??
$51 shipped to my door next week.
Reply #14June 30, 2011, 07:09:05 pm
vanagonturbo
  • 639
    • Fine Tuning
« Reply #14 on: June 30, 2011, 07:09:05 pm »
please do explain..
