Author Topic: TDI stumbles and miss fires  (Read 17009 times)
June 26, 2011, 02:09:13 pm
catlin_cava
  • 1954
« on: June 26, 2011, 02:09:13 pm »
its an ALH with bosch .216s and a Malone Stage 2 tune, 229K
The Issue, the car gets a boggy feeling, No power below 2000 then it will bog out and ill get a ton of black smoke come out and she'll start stumbling and miss firing. then it will stall out. its done it a few times to me.
Sometimes at an idle the car will idle very rought, and other times Idles great.
today it did it when I restarted it it was missing hard, and would barely idle. I had white smoke with Puffs of Black smoke.
Its not the Actualator I justed replaced it. My father in law thinks its the pump going(hes a diesel mechanic) He thinks its something to do with the advance in the pump.
and Ive had a few people tell me its the flywheel going. Whats going on so I can fix the damn thing lol.
and video you can hear it missing
Catlin
2010 VW Golf City 2.0L "Hers"
Reply #1June 26, 2011, 06:52:20 pm
Re: TDI stumbles and miss fires
« Reply #1 on: June 26, 2011, 06:52:20 pm »
I didn't hear any miss at all. When my tdi was still in the 98 body and i was driving it, the car would buck and roll the white smoke on take off or just lightly revving it.. yet it runs fine on the dolley in my garage right now..
However mine was an AHU, this is definitely fuel related. I dont know if the pump can be fully blamed, as it should continuously happen if something is mechanically wrong inside the pump you'd think.
Reply #2June 26, 2011, 07:10:42 pm
catlin_cava
  • 1954
« Reply #2 on: June 26, 2011, 07:10:42 pm »
Catlin
Reply #3June 26, 2011, 07:15:44 pm
« Reply #3 on: June 26, 2011, 07:15:44 pm »
I am no expert on the TDI by any means but mom's needed a flywheel and it sounded somewhat similar.
Reply #4June 26, 2011, 07:18:14 pm
catlin_cava
  • 1954
« Reply #4 on: June 26, 2011, 07:18:14 pm »
I could be but the car stalls and stumbles
Catlin
Reply #5June 26, 2011, 07:32:11 pm
« Reply #5 on: June 26, 2011, 07:32:11 pm »
True. I witnessed that in person, Catlin almost hit a BUS!.. lol
Man I dunno its messed, fuel restriction? There isn't any tests i can think of to test anything either..
Reply #6June 26, 2011, 07:51:57 pm
catlin_cava
  • 1954
« Reply #6 on: June 26, 2011, 07:51:57 pm »
Tomorrow me and Mani G are going to try and break it  ;D to see what the F its doing because shuttign it off kills the problem and erases the codes if there is any. I need the issue to happen to get the code while its running.
and yes that bus was scary no power steering going 50
Catlin
Reply #7June 26, 2011, 08:47:00 pm
Quantum TD
  • 1195
« Reply #7 on: June 26, 2011, 08:47:00 pm »
Impulse sender? They do go bad at higher mileage. If the sensor is not picking up the signal, it would cause a misfire. There really aren't many sensors on the TDI motor: coolant, impulse and vehicle speed. That's about it (and the 3rd injector).
I'd start at the impulse sender, and then go from there.
Reply #8June 26, 2011, 09:06:25 pm
catlin_cava
  • 1954
« Reply #8 on: June 26, 2011, 09:06:25 pm »
New Injectors, 3K on them lol, and they where built by Giles.
Catlin
Reply #9June 27, 2011, 09:22:02 am
rallydiesel
  • 1880
« Reply #9 on: June 27, 2011, 09:22:02 am »
I would second checking the flywheel. In the videos, it sounds like the engine itself is running fine. It's like there's something in the background that is rattling irregularly. If the flywheel is flopping around out of balance, it will affect the way the engine runs. Dual mass flywheels suck. I replaced mine before it even went bad and the clutch feel improved dramatically.
Or you could have a collapsed lifter.
« Last Edit: June 27, 2011, 09:30:34 am by rallydiesel »
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #10June 27, 2011, 12:29:05 pm
catlin_cava
  • 1954
« Reply #10 on: June 27, 2011, 12:29:05 pm »
Just hooked the vag com and when ever thr irregular sound happens the timing is all over the place, and the IQ Jumps like crazy on the irregular sound also
Catlin
Reply #11June 27, 2011, 12:49:48 pm
vanagonturbo
  • 639
    • Fine Tuning
« Reply #11 on: June 27, 2011, 12:49:48 pm »
are there any airbubbles in the feed line to the pump when its misfiring?
Reply #12June 27, 2011, 01:22:14 pm
catlin_cava
  • 1954
« Reply #12 on: June 27, 2011, 01:22:14 pm »
Nope, fuel line is clear filter was replaced prior to me getting the car
Catlin
Reply #13June 27, 2011, 02:38:19 pm
« Reply #13 on: June 27, 2011, 02:38:19 pm »
pull the out line nut.. is there any metal pieces in it?? if so pump going..
Reply #14June 27, 2011, 03:23:02 pm
vanagonturbo
  • 639
    • Fine Tuning
« Reply #14 on: June 27, 2011, 03:23:02 pm »
check coolant temp in engine with vag-com when misfiring is occuring. possibly a bad CTS?
