this is a new one it seems.....
Topic: this is a new one it seems..... (Read 2283 times)
June 19, 2011, 04:47:31 pm
lovinthedeez
June 19, 2011, 04:47:31 pm »
with the great weather and a little spare time, I finally took a minute to tear into the jetta. Took off the head to do a head gasket, and also to see if there was any catastrophic damage to the #3 cylinder, which wasn't firing it seemed. It was the only cylinder that wouldn't drop the rpm's after loosening the hard line nut, and I was expecting the worst. Well, the cylinder looked fine, but found a lot of carbon/crud in the combustion chamber. I also found a nice little crack underneath the #2 cylinder precup. That cylinder was firing fine. I realize a new/different head is on the shopping list, but what would cause the crack? Can't say I've really seen it happen often. I'll try to get a pic, but I don't have a camera right now. Gonna slap the head back on tonight and see if I can get this little sucker to run again. If it runs the same as before, I guess I'll do a compression check first, then go from there.....
June 20, 2011, 06:22:21 am
BillyWillicker
Re: this is a new one it seems.....
June 20, 2011, 06:22:21 am »
Oh, nice car! Just poking in as project direction has changed. I now have a rebuilt head for sale if interested. Only the orig. casting was used. PM me.
Jason
June 20, 2011, 09:46:53 am
June 20, 2011, 09:46:53 am »
check that injector.
June 20, 2011, 02:10:16 pm
June 20, 2011, 02:10:16 pm »
Quote from: 745 turbogreasel on June 20, 2011, 09:46:53 am
this
June 20, 2011, 03:23:23 pm
fdnyguy
June 20, 2011, 03:23:23 pm »
Your car brings back memories. I had an 84 in the exact same color. Along with a Rabbit pickup and a 2 door 82 Jetta coupe prior to the 84.
Before the internet and this site.......
Good luck with it,.
Stay safe, stay well. Jimmy
Never forget what a "Religion of Peace" did on 9/11/01.
2015 Passat TDi. 27k
1998 Jetta 1.9TTDi 228k .
2002 F250 7.3 TD 63,000 miles. Sold.
1980 Mack CF Fire Engine. Working on it.
2007 Dodge MegaCab 5.9 Cummins. Nice, but plagued with issues
June 20, 2011, 04:25:33 pm
lovinthedeez
June 20, 2011, 04:25:33 pm »
swapped it out already with a known good injector.......ran exactly the same
June 20, 2011, 08:22:57 pm
lovinthedeez
June 20, 2011, 08:22:57 pm »
all good......for whatever reason.....one injector, a head gasket, four hours labor, and seven months later, she revved to life right on the first try after bleeding and running like a champ......
Still gonna need a new head though
me and my 130 pounds torquing a head gasket....
Last Edit: June 20, 2011, 08:33:43 pm by lovinthedeez
