Author Topic: 2002 tdi. changed turbo-why is it smoking again?  (Read 6825 times)
June 16, 2011, 05:45:08 pm
motomike33y
  • 190
« on: June 16, 2011, 05:45:08 pm »
turbo died w/much smoke.  apparently bearings were gone judging from amount of play.  just replaced it w/used vnt-15 with less than 25000 miles.  changed oil and filter, started it and let it run a minute or so, revved it a little.  started easily, no smoke.  started it last nite and let it run while I fiddled with some things, revved it a couple times-again started and ran ok-no smoke. started it tonite to drive it home.  went down driveway and up hill on paved road and when I looked in mirror it was smoking blue smoke.  drove down the road a mile and turned around and came back and parked it.   smoking all the while. definite odor of burning oil.  noticed oil dripping from one of the tail pipes from the muffler.  when I headed homeward, noticed a visible oil trail on the paved road until I topped the hill.  Is this normal from oil left in the tail pipe/muffler?  or did I blow a seal or something?  I'm going to let it set for the weekend as I have other things to do, but I'm looking for hope and ideas other than tearing the turbo off again.  On a related note, how difficult is it to rebuild a turbo?  I have the old one and thought about doing that for a spare(and now it may be a necessity)
82 vanagon 1.6 waiting rebuild
81 jetta w/dasher 1.5 engine
91 jetta w/ 85 golf 1.6 NA- work in progress           suzuki samurai hardtop that may someday be diesel
2012 golf tdi
Reply #1June 16, 2011, 06:16:03 pm
81 vw pu
Re: 2002 tdi. changed turbo-why is it smoking again?
« Reply #1 on: June 16, 2011, 06:16:03 pm »
It takes a while to burn oil out of the exhaust system.
Keep an eye on the oil level in the engine to determine if the new/used turbo is bad.
Reply #2June 16, 2011, 09:06:40 pm
« Reply #2 on: June 16, 2011, 09:06:40 pm »
Yeah, my friend holed a piston in her Subie, and I changed the engine.
Leftover oil in the exhaust was so bad I didn't see anything but black behind me for 8 miles, and it smoked badly at least another 20.
Reply #3June 16, 2011, 09:09:31 pm
« Reply #3 on: June 16, 2011, 09:09:31 pm »
my fav was a 1.8t... blew the shaft apart.. filled exhaust with oil...
step on that bad boy and you could not see the trucks/cars behind you once i switched the turbo... got off interstate exit.. in a cloud of smoke.. and it covered the gasstation like some fright night horror movie.. was great,... took a good 50 miles..
Reply #4June 16, 2011, 09:10:10 pm
rallydiesel
  • 1880
« Reply #4 on: June 16, 2011, 09:10:10 pm »
Good advice. As far as the turbo goes, if the smoking doesn't clear up, a vnt is rebuildable but sourcing the parts is very difficult and they are not oem.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #5June 17, 2011, 05:11:17 am
motomike33y
  • 190
« Reply #5 on: June 17, 2011, 05:11:17 am »
thanks all, I'll sleep better this weekend until I can get back to it next week.
2012 golf tdi
Reply #6June 19, 2011, 05:26:57 pm
motomike33y
  • 190
« Reply #6 on: June 19, 2011, 05:26:57 pm »
let it set for the weekend, started it a couple times tonite----no smoke.  will try driving it Tues nite, but indications are it should be OK.  Thanks folks.
2012 golf tdi
Reply #7June 20, 2011, 11:09:02 am
« Reply #7 on: June 20, 2011, 11:09:02 am »
it doesnt smoke till it gets warmed up, does it?
its just the tons of oil left in the exhaust..
Reply #8June 22, 2011, 05:41:03 am
motomike33y
  • 190
« Reply #8 on: June 22, 2011, 05:41:03 am »
everyone was right, thankfully.  drove it about 25 miles last nite and the smoked stopped after the first 10
2012 golf tdi
