Author Topic: Silicon Reducers Size/Question  (Read 2256 times)
June 14, 2011, 05:40:34 am
ein bora
  • 377
« on: June 14, 2011, 05:40:34 am »
I need a 2.5 to 1.875 (63mm to 47mm) silicon reducer for my intercooler piping to turbo set up.
All I can seem to find is 1.75 or 2.0 to 2.5 reducers.
Which one should I use??
Thanks.
If you can't take advice - then you can't be helped!
Reply #1June 14, 2011, 06:09:33 am
DJPyro
  • 66
Re: Silicon Reducers Size/Question
« Reply #1 on: June 14, 2011, 06:09:33 am »
My experience with silicone couplers is that they don't stretch, so I'd say go with the 2.0 and clamp it tight. I think you'll have issues trying to squeeze the other one on. Use T-bolt clamps, you'll strip a worm gear clamp before you get it tight enough.
Reply #2June 14, 2011, 09:00:39 am
ein bora
  • 377
« Reply #2 on: June 14, 2011, 09:00:39 am »
Maybe the problem with that might be (as you can see in the picture) is that there is no lip on the turbo to stop the hose from sliding off, I wonder if it could be made tight enough to prevent that?
Reply #3June 14, 2011, 10:52:02 am
« Reply #3 on: June 14, 2011, 10:52:02 am »
I used a 2" silicone coupler with the 1.875" manifold inlet on my car without issue.  The T-bolt clamp had no trouble compressing it down that much.
Yeah definitely not a lot of meat on that turbo outlet to grab.  You could try roughening things up with a file and then clamping it good and tight.  Another option would be to weld a bead on the end of the pipe, if you have facilities to do so.  If not there's always this trick:
http://dsm.fidke.com/articles/diy-bead-intercooler-pipes-with-jb-weld.aspx
