Author Topic: Dasher Bracketry  (Read 2140 times)
June 10, 2011, 09:54:57 am
shwak23
  • 417
    • Blackdog Junkyard
Dasher Bracketry
« on: June 10, 2011, 09:54:57 am »
Can I use the Quantum AC/Alternator brackets on a dasher?
Reply #1June 10, 2011, 12:57:43 pm
Mark(The Miser)UK
  • 1557
Re: Dasher Bracketry
« Reply #1 on: June 10, 2011, 12:57:43 pm »
I can't see why not, but it means the correct a/c pump is required, the dasher uses a pump like the Rabbits I think...
Mark-The-Miser-UK
Reply #2June 11, 2011, 09:58:28 am
shwak23
  • 417
    • Blackdog Junkyard
« Reply #2 on: June 11, 2011, 09:58:28 am »
So... No possibility of using the Quantum AC pump? Is it just a mtter of swapping the pumps but continuing to use the Quantum bracket?
Also does anyone have issues with Alt. Belt tension with the AC equipped Dashers?
Reply #3June 11, 2011, 10:16:57 am
Mark(The Miser)UK
  • 1557
« Reply #3 on: June 11, 2011, 10:16:57 am »
I'm in an a/c free country, apart from my Yankee import  for my Quantum, but  as I understnd it, the pump follows the bracket, so use Quantum brackets and Quantum  'Briggs and Stratton' lookng 'York' pump, rather than the one that looks like a starter motor.
My kit was off a 1.6 gasser, so I may have issues when I come to fit it. :-\
Mark-The-Miser-UK
Reply #4June 11, 2011, 02:04:05 pm
Quantum TD
  • 1195
« Reply #4 on: June 11, 2011, 02:04:05 pm »
The Quantum uses a horrid boat-anchor York compressor (one large piston). It will sap what little power you have, but it will never die. You'll need the correct cast-iron bracket to mount it (even more weight!).
The Dasher used the Sanden rotary compressor. Lighter, but not as durable as the York. You'll need the welded/stamped steel bracket from the Dasher to mount it.
You can run either setup on any 1.6-2.0 motor from 1976-1993: gas or diesel
Or, you could fab your own auxilary brackets for the Quantum AC bracket, and then run a Sanden compressor.
