Author Topic: ALH weird noise on driving belt/timing belt side  (Read 10572 times)
June 09, 2011, 04:33:56 pm
gulmat
  • 21
« on: June 09, 2011, 04:33:56 pm »
Hi everyone, for about a month now i've been trying to figure out were that noise is coming from. I've changed the belt tensioner since the damper on it was toasted, changed the idler pulley and yet it's still doing that weird noise.
Also, the noise is only happening when the engine is hot and doesnt seems to happen when on idle
I've changed my timing belt at 336k and the car is at 378k right now
It's realy hard to tell where its coming from but i used a long screw driver(trick i learned in school) to listen to the a/c, alternator and steering pump and they don't seem to make any unusual noise  :-\
Here's a video i recorded today
http://www.youtube.com/watch?v=FIpMSsVUsPk
Feel free to tell me if i forgot to put some details!
Thanks alot!
« Last Edit: June 09, 2011, 04:35:33 pm by gulmat »
Reply #1June 09, 2011, 05:15:55 pm
catlin_cava
  • 1954
Re: ALH weird noise on driving belt/timing belt side
« Reply #1 on: June 09, 2011, 05:15:55 pm »
It's your 11mm pump screaming for a new owner ;)
Catlin
2010 VW Golf City 2.0L "Hers"
Reply #2June 09, 2011, 06:23:05 pm
gulmat
  • 21
« Reply #2 on: June 09, 2011, 06:23:05 pm »
Nice try catlin  ;D
Reply #3June 09, 2011, 08:34:14 pm
Quantum TD
  • 1195
« Reply #3 on: June 09, 2011, 08:34:14 pm »
What about the other 2 small rollers and the water pump? When were they replaced?
Also, it could be one of the other accessories. Have you pulled the serp belt to confirm?
Lastly, I've heard resealed pumps make a "squeegee" noise on the input seal.
Reply #4June 09, 2011, 09:13:54 pm
dankcorey22
  • 379
    Cummins!
    • Anything that runs
« Reply #4 on: June 09, 2011, 09:13:54 pm »
LOL  ;D
MY CARs-BLACK 99.5 Jetta TDI 5 speed 93,000- DC Stage 2 Clutch Kit 14Lb FW, Afe air intake box, 2.5" DP, 11mm IP, 2.5" stright piped, boost gauge, PP764, RC5 (WOW), 3-Bar, McNally EGT/Boost, 17/22, Race Pipe, EGR Cooler Delete, PD lift pump, R32 MAF housing,FMIC
1983 VW Jetta 1.6 turbo fuel mods
Reply #5June 10, 2011, 05:08:12 am
gulmat
  • 21
« Reply #5 on: June 10, 2011, 05:08:12 am »
the water pump have been changed, as for the 2 small roller i'd have to check with the garage or the receipt
I'll try and remove the serp belt today, i'll let you know if anything change  :)
Reply #6June 15, 2011, 10:38:03 am
gulmat
  • 21
« Reply #6 on: June 15, 2011, 10:38:03 am »
Alright folks, i looked with a flashlight at my timing belt and the probleme seems to be lower small roller, the thing doesnt even move! I ordered the part and probably changing it tomorrow!
Reply #7June 15, 2011, 05:41:27 pm
dankcorey22
  • 379
    Cummins!
« Reply #7 on: June 15, 2011, 05:41:27 pm »
I thought there was only one roller the top one. iirc but i could be mistaken its been awhile since ive done a timing belt on ALH thank God lol
Reply #8June 15, 2011, 06:01:26 pm
gulmat
  • 21
« Reply #8 on: June 15, 2011, 06:01:26 pm »
i wish there wasn't one but there's one..  >:(  and it doesnt seem too usefull haha!
« Last Edit: June 15, 2011, 06:03:08 pm by gulmat »
Reply #9June 15, 2011, 09:58:38 pm
« Reply #9 on: June 15, 2011, 09:58:38 pm »
An extra degree of wrap on the crank pulley?! Ridiculous...
so it was seized? WOWEEE, you coulda popped your engine.
Reply #10June 17, 2011, 02:35:52 pm
gulmat
  • 21
« Reply #10 on: June 17, 2011, 02:35:52 pm »
So, me and catling changed the lower small roller and boy was i lucky!
Here's a picture of how the roller was sitting  :o
but the thing that i was lucky with is that the ball bearing in it only gtfo of the roller yesterday so its been rolling like that for max 2h
Here's how much 2h of grinding metal to metal (old vs new) =
so let say, i would of rolled another 2h with that, well i would of probably needed a new engine!
Thanks all!
p.s ; Catlin's cat can fly!!!
Reply #11June 18, 2011, 04:03:17 am
dankcorey22
  • 379
    Cummins!
« Reply #11 on: June 18, 2011, 04:03:17 am »
Oh yeah i see now! glad you found your problem. that thing was GONE!  ;D
Reply #12June 18, 2011, 07:06:57 am
catlin_cava
  • 1954
« Reply #12 on: June 18, 2011, 07:06:57 am »
And think, you where debating about driving it home like that lol
Catlin
