Author Topic: Can't find valve stem seals  (Read 3242 times)
June 09, 2011, 03:48:45 pm
rallydiesel
  • 1880
« on: June 09, 2011, 03:48:45 pm »
The set my regular parts go-to place sent me are too small. They appear to be for 7mm valve stems because there is no way the protector caps will fit onto a valve stem. Also, they don't seat onto the guide without getting mashed. They even look smaller when compared to the old ones. Of course, the old ones were damaged on removal. The problem is all the part number in the online places are the same  >:(. So I am totally expecting them to send be another pack of the 7mm seals. Why does this always happen when you are just about to get the car back together and running?
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #1June 09, 2011, 07:22:25 pm
Re: Can't find valve stem seals
« Reply #1 on: June 09, 2011, 07:22:25 pm »
FEL-PRO Part # SS72567
CORTECO Part # 10017
BECK/ARNLEY Part # 0221482
From rockauto.com
