Author Topic: T3 42/36 trim VS K24  (Read 2181 times)
June 04, 2011, 01:22:44 pm
Big Daddy Roth
  • 298
« on: June 04, 2011, 01:22:44 pm »
I have a K24 on my AAZ syncro B3. It's to late for my liking. It only makes boost up to 17psi ish, and it takes alot of revs to get there.
I've looked at some maps and I think the T3 is a better match.
Opinions?
1993 TD B3 Sedan
1992 G60 Syncro B3 Sedan
Reply #1June 04, 2011, 01:50:27 pm
BillyWillicker
  • 111
Re: T3 42/36 trim VS K24
« Reply #1 on: June 04, 2011, 01:50:27 pm »
The k24 and t3 that will bolt up to the TD are dimensionally similar.  That being the case, they perform similarly,  It sounds like you would be better suited with a k14 or even better a gt15/vnt15.
Reply #2June 04, 2011, 03:02:39 pm
Big Daddy Roth
  • 298
« Reply #2 on: June 04, 2011, 03:02:39 pm »
The T3 I have is NOT the OEM 1.6 T3.
1993 TD B3 Sedan
Reply #3June 04, 2011, 03:31:55 pm
BillyWillicker
  • 111
« Reply #3 on: June 04, 2011, 03:31:55 pm »
OK, what are its specifications?
comp wheel trim/housing A/R?
turbine wheel trim/housing A/R?
Stock t3 is;
35 trim comp wheel, .42 A/R housing
standard trim turbine wheel, .36 A/R housing
All factory(vw, nissan, ford) t3 turbine wheels are the same size, they just use different turbine housings.
Reply #4June 09, 2011, 12:01:33 pm
Big Daddy Roth
  • 298
« Reply #4 on: June 09, 2011, 12:01:33 pm »
OK, it is the same as the OEM T3. No good to me then.
Gonna try a k14.
1993 TD B3 Sedan
