Author Topic: What would make a 1.6 just "stop"  (Read 1957 times)
June 03, 2011, 07:48:44 pm
trav1856
  • 230
« on: June 03, 2011, 07:48:44 pm »
Going to look at a turbo diesel and the guy said that it was just driving along just fine, and then all of a sudden wouldn't run anymore.
What do you think that would be? Fuel cut-off solenoid? Only thing that comes to mind for me.
1981 Rabbit Diesel
1981 Cabriolet
Reply #1June 03, 2011, 09:02:14 pm
Re: What would make a 1.6 just "stop"
« Reply #1 on: June 03, 2011, 09:02:14 pm »
broken timing belt/slipped cam gear
Clogged air/fuel filters
Depends many things, but how abruptly did it stop and that could rule out some.
Reply #2June 03, 2011, 09:19:42 pm
trav1856
  • 230
« Reply #2 on: June 03, 2011, 09:19:42 pm »
didn't say it was a broken timing belt, then again if it was, I suspect I'll have some bent valves at best?
1981 Rabbit Diesel
1981 Cabriolet
Reply #3June 03, 2011, 10:07:06 pm
DieselBalz
  • 301
« Reply #3 on: June 03, 2011, 10:07:06 pm »
What other noises were associated with the run-stop?
I also thought TB, as i remember being in a buddies car that had a tb pop and there were some unpleasant noises immediately afterwards. Before the cussing.
If it was nothing at all i would look at the fuel solenoid electrics and clogs like mentioned above.
