Author Topic: MKIII AAZ fan control module  (Read 2953 times)
May 26, 2011, 06:50:18 pm
Torchd
  • 372
« on: May 26, 2011, 06:50:18 pm »
My MKIII's fan control module is faulty and I am looking to order a new one but first I wanna know what the difference is between different FCM's since they all look pretty much the same but have different suffixes. Mine is 95 AAZ with AC and a 450w/250w/80w big motor with twin belt driven fan.
The original FCM is a 357 919 506 part number but I cant seem to find one and they are others available with Suffixes A,C,K. I heard that part numbers 357 919 506, 357 919 506 A and 3A0 919 506A are interchangeable.... is that true?
Cheers!
Reply #1May 26, 2011, 07:12:11 pm
nathan_b
  • 361
Re: MKIII AAZ fan control module
« Reply #1 on: May 26, 2011, 07:12:11 pm »
call the dealer, they will be able to tell you if it has been superseded.
81 caddy frankentd 02a, 99.9 tdi jetta, 00 golf
Reply #2May 26, 2011, 07:36:19 pm
Torchd
  • 372
« Reply #2 on: May 26, 2011, 07:36:19 pm »
We dont have a dealer in this country.
Reply #3May 27, 2011, 10:04:14 pm
Torchd
  • 372
« Reply #3 on: May 27, 2011, 10:04:14 pm »
Bump!
Reply #4May 28, 2011, 04:55:06 am
ein bora
  • 377
« Reply #4 on: May 28, 2011, 04:55:06 am »
How many wires go into the big and small connectors. All the ones I have - have three, but I know some out there have four.
« Last Edit: May 28, 2011, 05:45:25 am by ein bora »
If you can't take advice - then you can't be helped!
Reply #5May 28, 2011, 12:43:57 pm
  • 1739
« Reply #5 on: May 28, 2011, 12:43:57 pm »
On Vag-cat they list 2 for a 1995 AAZ Golf- 357 919 506 C and D. There are a few different versions depending on engine ,A/C etc etc but if you can find one with the same connectors and wires, it's worth trying
Reply #6May 30, 2011, 09:28:08 pm
Torchd
  • 372
« Reply #6 on: May 30, 2011, 09:28:08 pm »
4 wires in the bigger one and 10 pins in the smaller one.
The original one I took out of the car is 357 919 506 without any suffix.
Reply #7June 01, 2011, 10:51:43 am
Torchd
  • 372
« Reply #7 on: June 01, 2011, 10:51:43 am »
Bump.. help please!
