Author Topic: AAZ Valve Seals - help needed  (Read 2909 times)
May 26, 2011, 06:10:55 am
ein bora
  • 377
« on: May 26, 2011, 06:10:55 am »
I am having a problem buying the proper valve seals for my aaz. I have tried different manufacturers and keep getting ones that will not fit over the guides. I read on here someplace that the tdi uses the larger diameter seals - I ordered them and still get the smaller diameter ones. From what I can see there are two different sizes 7 and 8 mm but they both seem not to work.
I have like 30 or so of the wrong seals - just asking for a measly 8 of the right ones. :'(
Can some please tell me where I can buy the right ones, or the proper part number. Or even better yet if someone has a set - can I buy them.
Thanks.
If you can't take advice - then you can't be helped!
Reply #1May 26, 2011, 06:48:32 am
Mark(The Miser)UK
  • 1557
Re: AAZ Valve Seals - help needed
« Reply #1 on: May 26, 2011, 06:48:32 am »
Thanks.
Officially the 8mm ones are correct.
 The smaller ones are for the 16 valve setup. If they are a snug fit on the valve then they are correct.
The diameter of the valve sleeve should be 8mm.
Note they are not a finger tip push fit.
Use a 10mm or possibly 11mm 12 point socket, 3/8 or 1/2" drive to push them on.[check suitability by proffering a seal up to the socket, and it must pass the seal part and reach the chamfer. Very easy to 'spring' the coil spring off otherwise...
Mark-The-Miser-UK
Reply #2May 26, 2011, 08:28:40 am
ein bora
  • 377
« Reply #2 on: May 26, 2011, 08:28:40 am »
Here's a picture of what I mean. And yes I can get the 8mm ones on, but not without somewhat distorting them.
Reply #3May 26, 2011, 10:27:59 am
Thezorn
  • 381
« Reply #3 on: May 26, 2011, 10:27:59 am »
Yea they are gunna be the 8mm ones. I have some spares I can try and get a part number off of if I can find them.
Compounded 93 AAZ
Reply #4May 26, 2011, 01:08:39 pm
ein bora
  • 377
« Reply #4 on: May 26, 2011, 01:08:39 pm »
The numbers on mine are ELRING 1315, they also have Franco ERO on them.
I have checked the Elring site but I am not able to cross reference them.
Reply #5May 27, 2011, 01:29:45 am
Mark(The Miser)UK
  • 1557
« Reply #5 on: May 27, 2011, 01:29:45 am »
8mm ones are 026 109 675 [required]
7mm ones are 027 109 675
Remember, these fit tight enough that you will likely destroy them removing them; if for instance you forget the lower spring disc...
Mark-The-Miser-UK
Reply #6May 27, 2011, 05:24:05 am
Alcaid
  • 549
« Reply #6 on: May 27, 2011, 05:24:05 am »
Remember, these fit tight enough that you will likely destroy them removing them; if for instance you forget the lower spring disc...[/color]
I learned that the hard way....  ::)
'10 VW Passat 1.6TDI Highline
