Author Topic: FS 1.9 TD AAZ  (Read 4337 times)
May 23, 2011, 06:06:26 pm
G60Jetta
  • 13
FS 1.9 TD AAZ
« on: May 23, 2011, 06:06:26 pm »
1.9TD AAZ
~250,000 KM
Governor Mod/1.6 TD Boost Pin,
No IP Leaks
Metal HG,
New Rear Main Seal
New Coolant Y Pipe And Sensors
Fresh Oil Change
New T Belt
Possible Water Pump Issues ( Coolant Froze and when I thawed the motor and had it running wasn't flowing coolant, May been a blockage ) Shut it down before it overheated.
No Transmission/Clutch/Pressure Plate/Starter/Alternator/No PS Pump ( removed to run non P/S in my MK2 ) Saved the Alternator/Starter/Turbo W/ Manifold/ Aftermarket return line and DP for my DD.
Comes with Motor, IP, Water Pump, Spare Manifold, Turbo to IM Hose, A Dissembled K14 Turbo,
Heres how it sounded after I thawed it out and before I pulled the motor. Sat in the shed since.
450.00
Item Located in Lower Sackville Nova Scotia.
Message me for more questions...
Reply #1May 24, 2011, 01:49:01 pm
catlin_cava
  • 1954
Re: FS 1.9 TD AAZ
« Reply #1 on: May 24, 2011, 01:49:01 pm »
Good Guy! I recommend him
Catlin
2010 VW Golf City 2.0L "Hers"
Reply #2May 25, 2011, 09:50:14 am
Re: FS 1.9 TD AAZ
« Reply #2 on: May 25, 2011, 09:50:14 am »
 :o
OMG THATS A GOOD DEAL!!
wish i were a little closer..
bump for an AWESOME price.
Reply #3May 25, 2011, 05:23:39 pm
G60Jetta
  • 13
Re: FS 1.9 TD AAZ
« Reply #3 on: May 25, 2011, 05:23:39 pm »
If people want more detailed pictures just let me know, I can pull the VC off, BTW has no VC leaks.
Reply #4May 28, 2011, 09:11:51 am
Blocksmith
  • 261
    Wrench Lurker
Re: FS 1.9 TD AAZ
« Reply #4 on: May 28, 2011, 09:11:51 am »
PM
Green 83 Rabbit 4dr, 5 speed ACH trans swap, ported 1.6D mech lifter w/ vnt15, na pump w/ gov mod, gasser intake mani, 2.5" exhaust, bilstein sports and cut mk2 springs, ss brake lines, 14" vw bottlecaps
Reply #5May 28, 2011, 09:53:56 am
G60Jetta
  • 13
Re: FS 1.9 TD AAZ
« Reply #5 on: May 28, 2011, 09:53:56 am »
Getting quite a few PM's about shipping.
Coolant Gotta Be Flush, Oil Drained, Fuel Drained, Palatalized, Loaded from back shed into my truck and then find someone who will ship + the amount of paperwork. Aint worth my time, Sorry.
I ship small engine equipment ( pumps, generators etc ) thru work and its a hassle.
« Last Edit: May 28, 2011, 09:57:26 am by G60Jetta »
