Author Topic: 1.6 with Eaton M45  (Read 2140 times)
May 19, 2011, 03:27:00 am
kd4yor
  • 37
1.6 with Eaton M45
« on: May 19, 2011, 03:27:00 am »
I'm considering adding this little blower to a 1.6 NA motor. Just to run it at low boost (3-4) pressure to add power for climbing up hills. Has it been done before or is turbo the easy button
Reply #1May 19, 2011, 03:33:53 am
vdubspeed
  • 191
Re: 1.6 with Eaton M45
« Reply #1 on: May 19, 2011, 03:33:53 am »
turbo would be SO much easier and cheaper as parts are readily available. How do you plan to mount and spin that supercharger. 3-4psi won't even be noticeable.
I just slapped a turbo on my NA and went straight to 15psi.
It's not like a gasser where ANYTHING above vacuum is awesome.
Oh yeah...great to see another person from GA posting!
Reply #2May 19, 2011, 08:50:44 am
« Reply #2 on: May 19, 2011, 08:50:44 am »
a turbo will be better for hill climbing because it supplies more power and boost at lower rpms, it also spools the turbo more under load
Reply #3May 19, 2011, 09:52:47 am
« Reply #3 on: May 19, 2011, 09:52:47 am »
a supercharger would be sweet, but a turbo is definitely the easy button..
theres really not enough real estate for a supercharger, let alone a reliable way to drive one.. the crank nose on a 1.6 and AAZ are both weak..
