Author Topic: hylomar  (Read 4843 times)
May 18, 2011, 09:07:51 pm
ffgb
  • 244
hylomar
« on: May 18, 2011, 09:07:51 pm »
I am going to use hylomar with my HG but needed to know which one is better, the tube or spray?  I want to get the tube and use a small brush to apply to the block deck, head, and HG.  The spray seems nice to spray on the HG, but seems to difficult to spray onto the block deck and head because of the water passages, pistons, valves, etc...?  Any experiences with either?
Reply #1May 19, 2011, 09:31:36 am
sdwarf36
  • 159
Re: hylomar
« Reply #1 on: May 19, 2011, 09:31:36 am »
This may seem like crazy out of the box thinking-but maybe just spray BOTH sides of the gasket?  ::)
91 Jetta on WVO na / td swap in progress.
 "VW happiness is having 4 working door handles."
Reply #2May 19, 2011, 09:55:47 am
Re: hylomar
« Reply #2 on: May 19, 2011, 09:55:47 am »
thats what i do, spray both sides of the gasket. you dont need to spray the head or deck..
silver floral paint works decent to seal up head gaskets too..
Reply #3May 19, 2011, 10:15:20 am
ffgb
  • 244
Re: hylomar
« Reply #3 on: May 19, 2011, 10:15:20 am »
Thank you!  Now I just need to find somewhere in Southern California that sells hylomar in the spray can...I can find it in the tube, the spray can is difficult to locate!!!
Reply #4May 19, 2011, 09:06:22 pm
trav1856
  • 230
Re: hylomar
« Reply #4 on: May 19, 2011, 09:06:22 pm »
or find someone who will ship it to you, it just has to be marked ORM-D. USPS still handle 'em they just have to be marked properly:
ORM-D (Other Regulated Material) material is a limited quantity of a hazardous material that presents a limited hazard during transportation due to its form, quantity, and packaging. In almost all instances, the proper shipping name for an ORM-D material is consumer commodity. Not all hazardous material permitted to be shipped as a limited quantity can qualify as an ORM-D material. ORM-D materials having the proper shipping name of “consumer commodity” are mailable subject to USPS quantity and packaging standards.
1981 Rabbit Diesel
1981 Cabriolet
Reply #5May 20, 2011, 06:35:54 am
sdwarf36
  • 159
Re: hylomar
« Reply #5 on: May 20, 2011, 06:35:54 am »
Permatex- copper spray gasket-part #8697-availible everywhere. The silver paint trick is old school-but also works.
Reply #6May 20, 2011, 06:46:21 am
BigVWman
  • 332
Re: hylomar
« Reply #6 on: May 20, 2011, 06:46:21 am »
I thought the copper spray gasket is known to have bad reactions between aluminum and steel? Causing leaks down the road. Hylomar has always worked well.
Tim
83 rabbit shell 92 cabby tdi conversion, 91 cabby aba conversion, 87 cabby,  87 gti,  01nb tdi new project,00 1.8t nb, 98 ranger,92 f150 flareside(its pink) 97 cabrio and a 00 cabrio!
Reply #7May 20, 2011, 10:54:23 am
Re: hylomar
« Reply #7 on: May 20, 2011, 10:54:23 am »
I love hylomar, it's like nothing else out there. I put it on O ring connections and corroded old water necks things like that which tend to never seal well.
Incidentally, I have bought Hylomar off amazon.com along with a whole lot of other automotive items. You wouldn't expect so but amazon.com has a lot of automotive stuff, they are one of my primary sources for things.
Reply #8May 20, 2011, 11:28:45 am
Re: hylomar
« Reply #8 on: May 20, 2011, 11:28:45 am »
copper and aluminum do indeed have a reaction. when they come in contact, there is accelerated corrosion from both.. idk how bad it would be on a head gasket tho, there needs to be air present for corrosion to happen.
personally, i would only use copper head gasket sealer on a cast iron engine..
Reply #9May 21, 2011, 10:33:39 pm
maxfax
  • 2126
Re: hylomar
« Reply #9 on: May 21, 2011, 10:33:39 pm »
I prefer the tube..   For no other reason than it cuts down on waste..   No mater how well you think you cleaned out the spray nozzle and such, after they sit a bit they never seem to work right again..  If you can find the smaller cans that you can use the whole thing right away you might be fine..  Even if you spray te head, deck, and both sides of the gasket there is still a lot left in the can..
Last time I was on a search I could only find the large spray cans, and IIRC they ran about $40 shipped.. Haven't seen it in a store on the east coast for eons...
Copper stuff with aluminum heads is not good (ask a Mopar tech about Neon engines!)  The other thing about hylomar vs the copper spray is that they hylomar remains pliable, copper stuff does not.. It will allow some give during expansion and contraction and still remain sealed...
Reply #10May 22, 2011, 10:11:31 am
Re: hylomar
« Reply #10 on: May 22, 2011, 10:11:31 am »
all those neons had head sealing issues huh? like, it would corrode the head  so that it wouldnt seal, right?
Reply #11May 22, 2011, 10:23:11 am
maxfax
  • 2126
Re: hylomar
« Reply #11 on: May 22, 2011, 10:23:11 am »
The early ones were horrid..  It was a combination between corrosion, and just plain ole not sealing...  They used a MLS gasket with some variety of spray sealent that looked pretty coppery.. Typically there was no leaks in or out of the combustion chamber, usually started with external oil leaks followed by coolant...
Reply #12May 22, 2011, 01:34:15 pm
Re: hylomar
« Reply #12 on: May 22, 2011, 01:34:15 pm »
Actually, air does nothing.  It has to be in the presence of electrolyte.
your telling me that oxygen has absolutely nothing to do with corrosion?
Reply #13May 22, 2011, 02:34:38 pm
Re: hylomar
« Reply #13 on: May 22, 2011, 02:34:38 pm »
Not necessarily, as corrosion doesn't always refer to oxidation., other chemical reactions can occur which damage metal that don't involve oxidation. And, there is plenty of oxygen in water coolant, not just that which is bonded to hydrogen but in the form of dissolved gas.
