Author Topic: ip laying on its side??  (Read 3685 times)
May 17, 2011, 11:39:06 pm
polo_td
  • 65
« on: May 17, 2011, 11:39:06 pm »
Hi
I need to know if itīs possible to lay the pump on itīs side.
I have a polo diesel and the pump is turning left and is laying on its side so to say.
But now im in need of a lda, but my quest is is it possible to take a lda from a golf SB pump and install on mine?
will it work due to the fact that my pump is turning the "wrong" way, its laying down on itīs side etc etc.
Can any one help me with this information.
I was thinking that i maybe i could use a pump from T3 JX 1.6td with lda, but its hard to find here in sweden.
thomas
Reply #1May 18, 2011, 08:46:48 am
Re: ip laying on its side??
« Reply #1 on: May 18, 2011, 08:46:48 am »
from the pics of polos that ive seen, it looks like it would be hard to fit an LDA on one of those pumps. the backwards rotation wouldnt even matter. if it did, you could snag a volvo or audi diesel LDA, both of those pumps are rigged up like the polo..
Reply #2May 18, 2011, 11:54:21 am
« Reply #2 on: May 18, 2011, 11:54:21 am »
The rotation of the mainshaft of the injection pump doesn't matter to the LDA, but the rotation of the accelerator lever does.  If your accel lever rotates CCW when increasing fuel, then you could use a golf/jetta or even T3(JX) lda provided it will fit.  If you use the JX lda, you will likely need to custom bend the injection lines.  I don't think tipping the pump over on it's side will affect it's operation.
it shouldnt affect the LDAs opperation, but being that the pump is sideways, there may be something obstructing the LDA from even properly fitting..
Reply #3May 18, 2011, 02:25:42 pm
polo_td
  • 65
« Reply #3 on: May 18, 2011, 02:25:42 pm »
Okey!
Some new info for me to look into then.
Rotation of accelerator lever etc.
Will look into this and i wil get back with more questions.
thanx!!
Thomas
Sweden
