Author Topic: Source for injection pump throttle bushings  (Read 3064 times)
May 17, 2011, 10:57:33 am
Quantum TD
  • 1195
« on: May 17, 2011, 10:57:33 am »
Anyone know an online source for IP throttle shaft bushings aside from Prothe and my local Bosch dealer. I've got a couple really bad bushings that I need to swap out.
Thanx.
« Last Edit: May 18, 2011, 02:10:23 pm by burn_your_money »
Reply #1May 17, 2011, 03:30:32 pm
Re: Source for injection pump throttle bushings
« Reply #1 on: May 17, 2011, 03:30:32 pm »
Giles
Reply #2May 19, 2011, 04:33:28 am
rs899
  • 647
« Reply #2 on: May 19, 2011, 04:33:28 am »
I don't know of any others, but why don't you think the Prothe ones are "good enough" for this application?
Reply #3May 19, 2011, 08:20:10 pm
Quantum TD
  • 1195
« Reply #3 on: May 19, 2011, 08:20:10 pm »
They don't look like the originals, and I'm afraid they might leak.
Reply #4May 19, 2011, 08:41:57 pm
« Reply #4 on: May 19, 2011, 08:41:57 pm »
An O-ring will help........ ;D
Reply #5May 19, 2011, 09:03:55 pm
trav1856
  • 230
« Reply #5 on: May 19, 2011, 09:03:55 pm »
A lot of Prothe's parts either aren't to spec, or they're dissimilar to the OEM, or they're just horrible knockoffs. Now with all things, I'm sure there are *some* parts he sells that are reliable....but with him, I hear you have to take your chances and it's hit or miss.
1981 Rabbit Diesel
1981 Cabriolet
Reply #6May 20, 2011, 04:51:48 am
« Reply #6 on: May 20, 2011, 04:51:48 am »
Just rotate them 180 degrees. If they still leak it's not like they are hard to change.
