Author Topic: K-14 Wastegate Needed  (Read 4065 times)
May 09, 2011, 11:20:26 am
hippiekiller
  • 73
« on: May 09, 2011, 11:20:26 am »
need a beehive style wastegate for my jetta, the one I have is totally frozen and I have a feeling that I will bend it up trying to diss-assemble....thanks
95 jetta, 2"lift
92 dodge diesel too much to list
Reply #1May 09, 2011, 11:36:06 am
Re: K-14 Wastegate Needed
« Reply #1 on: May 09, 2011, 11:36:06 am »
try twisting the valve head back n forth.. my K24 gate was seized up, and i freed it by just twisting it back and forth for a while..
Reply #2May 13, 2011, 11:33:30 am
hippiekiller
  • 73
« Reply #2 on: May 13, 2011, 11:33:30 am »
cant really get it to turn more than 1/2" either way... >:(
95 jetta, 2"lift
Reply #3May 13, 2011, 11:52:35 am
« Reply #3 on: May 13, 2011, 11:52:35 am »
mine didnt even turn that far.. it turned a few degrees.. just enough to break the shaft loose, then i started spraying lube on it, and working it, then it freed up..
Reply #4May 18, 2011, 11:44:11 am
hippiekiller
  • 73
« Reply #4 on: May 18, 2011, 11:44:11 am »
Broke the shaft clean off....Still looking for a w/g unit...
95 jetta, 2"lift
Reply #5May 23, 2011, 05:15:36 pm
hippiekiller
  • 73
« Reply #5 on: May 23, 2011, 05:15:36 pm »
Or a complete turbo I dont have to rebuild ;D for under 150
95 jetta, 2"lift
