building mk2 track car, need some input on engine mods
Topic: building mk2 track car, need some input on engine mods (Read 6241 times)
May 06, 2011, 06:40:37 pm
xtrigger
User+
d3lahk
May 06, 2011, 06:40:37 pm »
Basic plans are to build an mk2 golf into a track car for fun in the summer...
I currently have a 86 westy golf with 1.6 n/a
I have all the parts to convert to turbo
I was going to ditch the diesel entirely and go directly to a 16v 9a from a passat, but i relized I might be able to achieve the same power levels and remain diesel
Im wondering if i go with a 1.6TD k24 fuel mod and gov mod, intake, exhaust and intercooler and boost it ~25psi
will i be able to achieve decent power levels to make it a proper competitor on the track?
main reason I want to go this route is that, its super easy to wire up, very simple and cheap to run, and DIFFERENT!
car will be lightened as much as I can without having it non street legal
THANKS
1986 VW Jetta TDI
May 06, 2011, 07:19:32 pm
Pat Dolan
Re: building mk2 track car, need some input on engine mods
May 06, 2011, 07:19:32 pm »
Competitor to what? What kind of track/racing, what class?
lifetime VW enthusiast, racer, fixer, addict, etc.
'03 TDI Variant, MkII Golf Country, Mk1 and II Scirocco (gassers), a Vanagon aircooled, an Audi 2.0 TD waiting to become a Porsche TD (in my M471 924), FLD120/DDEC IV, Ford 7.3/450, Iveco D220 and some 6D14T Mitsus and a few more.
May 06, 2011, 07:29:41 pm
xtrigger
User+
d3lahk
May 06, 2011, 07:29:41 pm »
open track days, nothing specific, just run what you have basically
just im looking for 16v performance out of the 1.6td
if its feasible I think its the route to go (have been doing some research it seems it is) but i need a solid answer
thanks
1986 VW Jetta TDI
May 06, 2011, 08:19:55 pm
Pat Dolan
May 06, 2011, 08:19:55 pm »
You need about 150HP to be in 16V company, so anything close to that will be fantastic. However, I must defer to the IDI gurus to know what it takes to get there (can tell you for ALH).
May 06, 2011, 08:25:32 pm
blackdogvan
May 06, 2011, 08:25:32 pm »
You'll have more fun with the 16v.
1991 Vanagon 1.9 mTDI
May 06, 2011, 09:04:39 pm
xtrigger
User+
d3lahk
May 06, 2011, 09:04:39 pm »
thanks for the input
1986 VW Jetta TDI
May 06, 2011, 10:38:56 pm
nathan_b
May 06, 2011, 10:38:56 pm »
my franken motor is in the 100-110 hp and does 0-60 in 9s.
stock 16v gti is around 8.5s 0-60, with the torque and low end power, you can do much better in the corners than a reving 16v.
Go diesel, hp means nothing, ( well a lot less than gassers) A 125hp idi (easy with stock pump tunes and k24 and intercooler) will feel like a 200hp gasser.
81 caddy frankentd 02a, 99.9 tdi jetta, 00 golf
May 07, 2011, 03:25:05 am
Alcaid
May 07, 2011, 03:25:05 am »
For track use, the #1 most important upgrade is a good oil cooler!
'03 VW Golf PD130 4Motion Highline
'10 VW Passat 1.6TDI Highline
'83 VW Jetta 1.6TD, 11mm pump, H-beam rods, girdle, fully reworked AAZ head +++ Going Compound
May 07, 2011, 07:22:57 am
blackdogvan
May 07, 2011, 07:22:57 am »
Have you heard of the chump car world series? Without a doubt the most fun automotive fun i've ever had. It's similar to the Lemons 24hr race series.
www.chumpcar.com
If you can check out a race near you I can pretty much guarantee you'll want to build a car for it. Diesel would be interesting, there is a team near us building a mid engine crappy caddy. They are thinking about a mtdi for it i think. Heat soak is the enemy tho.
May 07, 2011, 12:42:15 pm
macka
May 07, 2011, 12:42:15 pm »
cool 2 events in Brainerd MN
Quote from: Vincent Walden
I do know that I drive torque, while listening to my friends prattle on about horsepower.
May 07, 2011, 03:55:42 pm
macka
May 07, 2011, 03:55:42 pm »
Audi makes an IC that is pretty much perfect for a modified 1.6 its PN 035 145 805 E
Reply #11
May 08, 2011, 07:33:38 am
xtrigger
User+
d3lahk
Reply #11 on:
May 08, 2011, 07:33:38 am »
ill be running duel rad fans and an oil cooler for sure
with gauges to monitor everything, EGT, OIL temp/press, Volts
is there any gain or at least put less stress by running an intank fuel pump to aid the IP draw fuel?
basically TD the stock 1.6 (which runs like new, PO was a diesel tech) Gov Mod, Fuel Mod, IC, k24, ~20psi, intake, exhaust
nathan_b, is it ok if i get more info about your setup, i need to be able to convince my friend into sticking diesel lol
The fact its easy to tune, easy to setup, easy to mod, cheap to operate, and reliable... should make for fun track days and save use some money
thanks for all the info
Last Edit: May 08, 2011, 08:23:00 am by xtrigger
1986 VW Jetta TDI
Reply #12
May 08, 2011, 08:49:04 am
DieselBalz
Reply #12 on:
May 08, 2011, 08:49:04 am »
I read through the entire rules section of that Race Series. A friend of mine has tapped me to help him at the one down here in Sebring, FL. (They run the full Gran Prix Circuit!) It looks like a *** ton of fun. He runs an ABA with a Carb Setup, the air cleaner sticks outta the hood. It is beast. Mk3 Golf for the shell.
Even with all the mods I would think your best strategy would be fuel mileage. The race is based on distance traveled. Tune the turbo and the pump to give you some fun, cause it is a race after all, but keep fuel mileage as your ace in the hole. You arent gonna be some rocket ship thats gonna be lapping capable cars based on who's faster, youre gonna be lapping cars cause they have to go in and get another belly of go juice. And youre nowhere near empty.
If that is the series youre gonna try for. Going with that strategy could really give you the ability to keep costs super low, and the money you save there, you can throw at the bits of the car that are exempt from the 500 dollar limit like brakes, exhaust and tires!
Plus you have super spy deterrents with your diesel. Like shifting up a gear more than where you need to be and dumping the throttle as you go into a turn with someone beating up your back bumper.
Go go Golfdjet Smoke Screen!
Reply #13
May 08, 2011, 04:46:46 pm
nathan_b
Reply #13 on:
May 08, 2011, 04:46:46 pm »
81 caddy with a 1.6 w/ 1.9aaz head. K14 running 18psi. Toyota supercharged mr2 intercooler mounted next to the rad. mild governor mod. ground lda cone. fuel turned up, throttle arm rotated. with 15" tires it got 45mpg at 75mph taking it easyish. easy it gets 50mpg. Hard beating it on the daily commute, 38-41.
cruises 75mph with egts below 650.
can go 100 (on gps not speedo) with egts under 1100,
on a closed circuit of course.
0-60 around 9s.
I think it would beat a stock 16v swapped caddy, but my motors not stock, so take that for what you will. but it will beat my mk3 jetta to 60 and it's an aba with a 268 cam, chip, bilsteins and a 2.5 echaust. Not a rocket, but respectable to say the least.
Reply #14
May 12, 2011, 02:40:57 pm
xtrigger
User+
d3lahk
Reply #14 on:
May 12, 2011, 02:40:57 pm »
thanks, will update soon as I move back
1986 VW Jetta TDI
