Author Topic: MKI TRANNY INTO A MKII?  (Read 9046 times)
May 03, 2011, 09:39:36 am
shwak23
  • 417
    1990 VW Golf TD. Engine Code CY
    • Blackdog Junkyard
« on: May 03, 2011, 09:39:36 am »
Lost 5th in my MKII. Is there anyway I can squeeze a MKI Diesel tranny [That I already own] into my MKII? For cheaper than it would cost to buy/fix my silly gasser tranny I have now?
Reply #1May 03, 2011, 12:46:46 pm
Re: MKI TRANNY INTO A MKII?
« Reply #1 on: May 03, 2011, 12:46:46 pm »
what trans are you taking out? does it have 100mm axle flanges?
whats going back in there? if its a mk1 diesel trans, it DOES NOT HAVE 100mm axle flanges..
gotta make sure your axle flanges are 90mm to fit the mk1 trans, or swap your inner CV joints to 90mm units.
but if you already have 90mm axles, then it should fit fine.
Reply #2May 03, 2011, 02:13:16 pm
shwak23
  • 417
    • Blackdog Junkyard
« Reply #2 on: May 03, 2011, 02:13:16 pm »
Ok well lets say the axles are non issue does the tranny bolt in? Do the mounts all work? Or does it require more fabrication?
Reply #3May 03, 2011, 02:30:18 pm
« Reply #3 on: May 03, 2011, 02:30:18 pm »
its an 020, yes it will bolt in place of another 020, but you may not be able to hook up the axles.. if you cant hook up your axles to it, i wouldnt even worry about if it fits or not..
but yes, it SHOULD fit. as long as the final drive housing is drilled to accept the mk2 style rear mount.. and of course, the axle flanges fitting the axles..
you may have to change the gear selector linkage on the trans to the mk2 piece. i guess they ARE different..
Reply #4May 03, 2011, 02:41:00 pm
shwak23
  • 417
    • Blackdog Junkyard
« Reply #4 on: May 03, 2011, 02:41:00 pm »
Would the final drive housing be drilled? I guess this is all speculation without the codes eh?
Reply #5May 03, 2011, 02:42:00 pm
« Reply #5 on: May 03, 2011, 02:42:00 pm »
exactly why i asked in my first post what you were taking out, and wanting to put back in..
Reply #6May 03, 2011, 02:53:24 pm
shwak23
  • 417
    • Blackdog Junkyard
« Reply #6 on: May 03, 2011, 02:53:24 pm »
Well I'll run outside in a minute and check it out. It'd be so super awesome if I could pull this off.
Reply #7May 03, 2011, 05:17:50 pm
BigVWman
  • 332
« Reply #7 on: May 03, 2011, 05:17:50 pm »
long run eh!
Tim
83 rabbit shell 92 cabby tdi conversion, 91 cabby aba conversion, 87 cabby,  87 gti,  01nb tdi new project,00 1.8t nb, 98 ranger,92 f150 flareside(its pink) 97 cabrio and a 00 cabrio!
Reply #8May 03, 2011, 06:42:04 pm
« Reply #8 on: May 03, 2011, 06:42:04 pm »
Reply #9May 03, 2011, 08:21:55 pm
« Reply #9 on: May 03, 2011, 08:21:55 pm »
Just look at the mk2 tranny and see how it mounts then look at the mk1 tranny and see if it has what needs to be drilled. You could modify it to fit if need be...
Reply #10May 03, 2011, 08:33:47 pm
Quantum TD
  • 1195
« Reply #10 on: May 03, 2011, 08:33:47 pm »
These are the only MK1 trannies that will bolt into a MK2:
7A
9A
4K
2H
All the other ones (FF, FO, FM, FK, FN, F---, etc) will not bolt into a MK2. They lack the bosses on the differential housing for the MK2/3 rear mount.
A quick way to tell if the trans will work, is to look and see if the driver's side flange has a GREEN metal cup behind it that holds the seal. If it does, you're good to go. If it doesn't, it won't fit without you modifying the rear trans mounting.
Reply #11May 03, 2011, 08:35:11 pm
shwak23
  • 417
    • Blackdog Junkyard
« Reply #11 on: May 03, 2011, 08:35:11 pm »
Damn that was a long run!! All the way to the next town over where I pulled a different tranny blah blah blah i'm h4rDc00rzz. ;D
7A03113 is the tranny code.  :-[
Looks like i'm *** outta luck. Or sompin.
Edit: Lol that warning that comes up that says "a new reply has been posted you may want to review your response"... I ignored it... But apparently i shouldn't have.
Man.. I'm so pumped it'll work. I was going to be so mad if it was the FF's that would fit and the 7A's wouldn't. I just sold a perfect FF. I'm gonna swap this asap.  ;D ;D ;D
« Last Edit: May 03, 2011, 08:46:21 pm by shwak23 »
Reply #12May 04, 2011, 04:21:41 am
BigVWman
  • 332
« Reply #12 on: May 04, 2011, 04:21:41 am »
swap cases!
Tim
Reply #13May 04, 2011, 09:05:19 am
shwak23
  • 417
    • Blackdog Junkyard
« Reply #13 on: May 04, 2011, 09:05:19 am »
swap cases!
eeewww that sounds hard.  ;D
Reply #14May 04, 2011, 11:12:05 am
shwak23
  • 417
    • Blackdog Junkyard
« Reply #14 on: May 04, 2011, 11:12:05 am »
Ok so I have the 7A but my Golf is a 1990 Golf Gasser converted to a Diesel but with the Gasser tranny.  ::) Thank you PO.  ::) Are my flanges good to go or should/can I swap the two?
Edit: By this I mean is one 100mm and one 90mm and can they be swapped?
« Last Edit: May 04, 2011, 11:30:26 am by shwak23 »
