Author Topic: AAZ knocking/timing  (Read 9801 times)
Reply #15May 04, 2011, 10:30:44 am
Big Daddy Roth
  • 298
Re: AAZ knocking/timing
« Reply #15 on: May 04, 2011, 10:30:44 am »
have you checked that all the bolts are there for your injection pump bracket?
Good call. I'll check those this afternoon.
Maybe it worth mentioning that I have the later almost-tdi style AAZ pump. I mounted it to an earlier bracket that I bored out to fit the hub of the pump.
1993 TD B3 Sedan
1992 G60 Syncro B3 Sedan
Reply #16May 04, 2011, 10:38:46 am
« Reply #16 on: May 04, 2011, 10:38:46 am »
doesnt the 2 piece sprocket have a DIFFERENT OFFSET than the standard pulley? i swear i read that somewhere..
Reply #17May 04, 2011, 10:56:01 am
Big Daddy Roth
  • 298
« Reply #17 on: May 04, 2011, 10:56:01 am »
Are you saying it's possible that I have the wrong belt gear on the pump? I also thought i read that somewhere.
1993 TD B3 Sedan
Reply #18May 04, 2011, 10:58:09 am
« Reply #18 on: May 04, 2011, 10:58:09 am »
would be pretty hard to time it if you got the wrong sprocket on there.. i think?!
im not positive, but i swear i read that the 2 piece sprocket is different offset from the 1 piece unit.. someone else should confirm/deny that..
Reply #19May 04, 2011, 11:19:37 am
Big Daddy Roth
  • 298
« Reply #19 on: May 04, 2011, 11:19:37 am »
1993 TD B3 Sedan
Reply #20May 04, 2011, 01:01:33 pm
« Reply #20 on: May 04, 2011, 01:01:33 pm »
Reply #21May 04, 2011, 01:09:34 pm
Big Daddy Roth
  • 298
« Reply #21 on: May 04, 2011, 01:09:34 pm »
no, my pulley does. it's one piece.
1993 TD B3 Sedan
Reply #22May 04, 2011, 07:59:10 pm
Big Daddy Roth
  • 298
« Reply #22 on: May 04, 2011, 07:59:10 pm »
I there any other way to find TDC on a aaz?
1993 TD B3 Sedan
Reply #23May 04, 2011, 09:02:04 pm
Big Daddy Roth
  • 298
« Reply #23 on: May 04, 2011, 09:02:04 pm »
1993 TD B3 Sedan
Reply #24May 05, 2011, 03:45:07 am
Mark(The Miser)UK
  • 1557
« Reply #24 on: May 05, 2011, 03:45:07 am »
If you are going to use the dial gauge method, then do it by approaching TDC from two directions. Because:
 1) There are a lot of 'stationary' points for the piston at TDC, and
2) bearing slop.
Thus you will get two positions for TDC which you bisect.
A better way is to bisect from either side of TDC using a dropped valve.
Best way to do this; [my invention, but I give it here for you all to use freely and including those who wish to sell it, as my overriding interest is to offer  help], is to take an old flat screwdriver, heat the end up just behind the flat area and bend slightly.
Use this to give a repeated constant 'camlobe' by pushing up to bend in screwdriver.
Use as you approach TDC on compression stroke, and remove to turn engine through TDC before reinserting. Go far enough away from TDC to ensure slackness taken up.
Bisect the readings.
Mark-The-Miser-UK
Reply #25May 05, 2011, 08:47:58 am
Big Daddy Roth
  • 298
« Reply #25 on: May 05, 2011, 08:47:58 am »
I don't believe my CAM timing is out 6*. I set all of the timing correctly once (w/ diesel fw), and haven't moved it ever. This engine has since had 2 different fw's on it. However, I have never moved the cam. Which is why bad things haven't happened.
I did last night take the VC off and check it. When I have the engine at the fw TDC, the cam is back about 1*. So, if you remember that if I set the pump back to around .6mm (using the fw tdc), it runs fine. So if I consider the fw mark to be ahead by 1* error, the 0.6mm retardation would be a reasonable measurment.
I need to find actual TDC.
1993 TD B3 Sedan
Reply #26May 05, 2011, 04:32:10 pm
« Reply #26 on: May 05, 2011, 04:32:10 pm »
I rolled it to the correct mark and rolled the pump back a little bit. This fixed my issue. Thanks.
I`ll borrow the tools and time it correctly tomorrow.
Have you corrected the *CAM* timing.  That picture I posted is not a joke...
no, the picture is NOT a joke, it can happen. and the sad thing is, that was a fairly mild explosion Libby posted up.. ive pulled apart engines with valve heads sticking thru the top of the piston..
Reply #27May 05, 2011, 04:53:20 pm
« Reply #27 on: May 05, 2011, 04:53:20 pm »
You need to move the cam each time you "time" the engine and tention the belt. If you changed FW then that needed done. Unless you have a degree wheel there is no way of knowing how far you are off. More than a tooth of the belt either way makes disaster happen. Crank at TDC, IP locked, cam lock in place is the only real safe mode here. For cam to crank you wouldn't even need the IP locked, but it is good measure to do so.
Reply #28May 09, 2011, 08:17:02 am
Big Daddy Roth
  • 298
« Reply #28 on: May 09, 2011, 08:17:02 am »
I set the pump where it wants to run. LOTS of HP now. This thing is gonna eat VR6's for breakfast.
1993 TD B3 Sedan
Reply #29May 09, 2011, 04:18:14 pm
nathan_b
  • 361
« Reply #29 on: May 09, 2011, 04:18:14 pm »
I did a timing belt on a late model aaz jetta today (somehow ended up registered in the US... ???)
it had the 2 piece pump pulley and I timed it like you should for the 2 piece and checked it with a dial indicator and it was like 0.85, I set it to 1.00 , and it runs much better. Quiet too, just a note, don't trust that for timing to be spot on without a dial indicator.
81 caddy frankentd 02a, 99.9 tdi jetta, 00 golf
