Author Topic: WTB, vane vacuum pump  (Read 5437 times)
April 30, 2011, 01:08:48 pm
« on: April 30, 2011, 01:08:48 pm »
I am so sick of changing the diaphragm on my current pump I decided to go for the newer style. I've probably spent 80 bucks buying replacement diaphragms in the last 5 years trying to "save money" by not upgrading.
So, let me know what you have and what you want for it. Thanks
Reply #1April 30, 2011, 01:14:46 pm
truckinwagen
  • 1895
Re: WTB, vane vacuum pump
« Reply #1 on: April 30, 2011, 01:14:46 pm »
I have one, $30 plus shipping takes it!
-Owen
83 Opel Kadett Diesel
Reply #2May 02, 2011, 12:26:59 pm
« Reply #2 on: May 02, 2011, 12:26:59 pm »
Sounds good, I hate hard brakes.
You'll have a pm shortly.
Reply #3May 02, 2011, 12:43:48 pm
« Reply #3 on: May 02, 2011, 12:43:48 pm »
my vane pump intermittently quits supplying vacuum.. actually, both of my vane pumps were that way..
Reply #4May 02, 2011, 01:05:33 pm
« Reply #4 on: May 02, 2011, 01:05:33 pm »
Mine consistently dies every year.
Reply #5May 02, 2011, 01:21:37 pm
« Reply #5 on: May 02, 2011, 01:21:37 pm »
you got a diaphragm pump tho, so its kinda expected.. mine is a vane pump.. they are supposed to be trouble free..
Reply #6May 02, 2011, 01:23:38 pm
« Reply #6 on: May 02, 2011, 01:23:38 pm »
Now I'm remembering that there's a difference in length between the old and new style.
Do I have to measure mine?
Reply #7May 02, 2011, 01:25:44 pm
« Reply #7 on: May 02, 2011, 01:25:44 pm »
length of what? as long as your vacuum pump doesnt have a coiled up oil supply line, it should be a direct swap from your diaphragm pump..
only pump i know for sure wont work, is an AAZ pump..
or are you talking about the drive for the oil pump?
they come in 2 styles.. flat against the bottom of the gear, and recessed ~3/8" up into the gear.. the vane pump only comes one way, so hope its the same as what you have, other wise you will need a new oil pump with the correct length shaft..
« Last Edit: May 02, 2011, 01:27:49 pm by R.O.R-2.0 »
Reply #8May 02, 2011, 01:36:22 pm
« Reply #8 on: May 02, 2011, 01:36:22 pm »
I just compared my diaphragm pump and vane and they're the same.
The oil pump drive is recessed 3/4 up inside the gear on both.
« Last Edit: May 02, 2011, 05:06:46 pm by rabbitman »
Reply #9May 03, 2011, 12:53:37 pm
« Reply #9 on: May 03, 2011, 12:53:37 pm »
then your good to go, i think only the early engines got the short oil pump shaft..
Reply #10May 03, 2011, 03:29:57 pm
« Reply #10 on: May 03, 2011, 03:29:57 pm »
I made the last two diaphragms out of 1/8" rubber and the first one lasted a couple months and the second is dying after only a week or two. I got sick of buying new $12 diaphragms.
Good to know about the old pumps.
Reply #11May 04, 2011, 08:23:24 am
« Reply #11 on: May 04, 2011, 08:23:24 am »
i had to swap out the vacuum pump and oil pump at the same time when i boosted my 1.5
good thing i noticed the shafts were different lengths, because the new vac pump would not have turned the old oil pump.
Reply #12May 09, 2011, 06:18:29 pm
« Reply #12 on: May 09, 2011, 06:18:29 pm »
Hey, thanks man I got it today! :D
