General Information
Troubleshooting
ALH Serpentine tensioner noise?
Topic: ALH Serpentine tensioner noise? (Read 5685 times)
April 28, 2011, 12:42:46 am
April 28, 2011, 12:42:46 am »
02 Golf has a rattle where the top bolt of the tensioner shock goes through.
I can hush it up with medium fingertip pressure.
Anyone fixed this without buying a tensioner assembly?
May 02, 2011, 05:30:29 pm
redneck_vdub
Re: ALH Serpentine tensioner noise?
May 02, 2011, 05:30:29 pm »
Mine does the exact same thing, and ive checked to make sure the bolt is tight. Must be the design. Oh and it is a new tensioner.
'01 Golf TDI "The Redneck V-Dub"
360,000kms on the body; 17,000kms on the engine
EGR delete, 2.25" turbo back, air box mod, Giles injectors, VNT 17, ARP headstuds, 14LB flywheel, boost and EGT gauges.
Oo=w=oO
May 02, 2011, 07:52:22 pm
May 02, 2011, 07:52:22 pm »
I'm not sure that's what I wanted to hear
But I suppose I can hold off on buying another.
May 03, 2011, 07:52:23 pm
May 03, 2011, 07:52:23 pm »
its a diesel shes supposed to have some rattles
May 06, 2011, 06:43:26 pm
redneck_vdub
May 06, 2011, 06:43:26 pm »
Quote from: 8v-of-fury on May 03, 2011, 07:52:23 pm
True enough lol.
Oo=w=oO
May 06, 2011, 08:01:58 pm
May 06, 2011, 08:01:58 pm »
did you try to just remove the shock. They leak and end up useless. The real problem is if the spring is soft, and not keeping enough tension on the belt. Not as critical as on an AAZ, but can still damage the crank if left for a long time.
General Information
Troubleshooting
