Oil Squirters Removal/Honing Block
Topic: Oil Squirters Removal/Honing Block (Read 2505 times)
April 13, 2011, 07:34:59 pm
ein bora
April 13, 2011, 07:34:59 pm »
On my aaz they are held in with a fairly small bolt, when I tried to remove the bolts they didn't want to come loose to easily so I didn't try any further as I am afraid I may break one. Is this normal or what do I need to do in order to get them out safely.
Thanks.
If you can't take advice - then you can't be helped!
April 13, 2011, 07:37:36 pm
BillyWillicker
Re: Oil Squirters Removal/Honing Block
April 13, 2011, 07:37:36 pm »
They are loctited in reall good. Give 'em a twist.
April 14, 2011, 05:40:52 am
DJPyro
April 14, 2011, 05:40:52 am »
Yeah mine all broke free pretty easily, but the breakaway torque was pretty high on them... You'll be fine.
April 14, 2011, 10:19:56 pm
April 14, 2011, 10:19:56 pm »
If they are hard to unscrew, sometimes I'll put the bit in place and smack it with a hammer.
April 15, 2011, 04:59:56 am
ein bora
April 15, 2011, 04:59:56 am »
Once I found out that they where Loctited in - they came out with no injuries to me or the bolts.
As always, great information. Thank you.
April 15, 2011, 09:30:01 pm
April 15, 2011, 09:30:01 pm »
Remember to put some sealant around the part that plugs into the block when you reinstall.
