Author Topic: used ATF as fuel  (Read 2365 times)
April 13, 2011, 01:12:32 pm
NA diesel
  • 8
used ATF as fuel
« on: April 13, 2011, 01:12:32 pm »
As the title suggests, I would like to discuss the use of filtered used ATF and used engine oil as fuel or a fuel supplement/additive in a 1.6L diesel. Any thoughts or comments?  Anyone done this?  What have you done to filter and/or pre-treat the ATF or oil?  What ratio of ATF or oil to diesel was used, with what results?
« Last Edit: April 13, 2011, 01:18:36 pm by NA diesel »
Reply #1April 13, 2011, 04:06:08 pm
Re: used ATF as fuel
« Reply #1 on: April 13, 2011, 04:06:08 pm »
This has been covered before. You should find some decent info in the archives. Proper filtering is KEY
Reply #2April 13, 2011, 10:49:41 pm
mystery3
  • 774
« Reply #2 on: April 13, 2011, 10:49:41 pm »
Search wmo and about three pages o' info pop up. If that leaves you with questions fire away!
