Fixmyvw.com
Author Topic: AAZ head on an NA? :D  (Read 3824 times)
April 10, 2011, 01:09:42 am
« on: April 10, 2011, 01:09:42 am »
Ok so heres the thing fella's..
My head gasket is leaking a good amount of oil at the drain in between cyl 3 and 4, which then dripped down the front side of the transmission and seeped in to my bell-housing.. Can ya say slipping clutch? :( Its not too bad.. must have only gotten a small amount in there.. I have been contemplating spraying some brake cleaner in there, it wont hurt eh?
Anyway! so the HG is leaking, and will need replaced because this car needs to be a reliable one as well if its going to be my backup ;) This is actually an awesome story. I bought this car in 07 as a 1.7 gas with 167k km on it. 08 i picked up a wrecked running 91 golf for $350 stripped it for the engine/tranny, wheels and seats. Junked the rest. Broke even on the scrap, and parts i sold. It was maintained well, until stupid put the cruise on and fell asleep.. Anyway that motor got shoved to the back of the garage in dec 08. Sat there till i got my 81 1.6D in sept 09, where its parts became useful for that engine. Got it all good and buttoned up and drove it until sept 10 where i picked up a non running 98 tdi for $400. got it running and drove it for a month or two while i stripped the 81 for the TDI swap, then i started driving the gas one while i stripped the tdi oct 10. Traded the tdi shell for a running 91 1.6td, which we put in my brothers 84 in place of his gas engine.. which i then added to the 91's trunk along with a washing machine for scrap to get back over half of what i payed for the TDI.. AND NOW that original 1.6 na i bought in 08 has finally made its way in to the car it was intended for! my 84!
From what i recall the aaz head, will be direct swap to a hydraulic 1.6? yes? a 1.6/1.9 N/a hybrid? Why not eh I have the head sitting here that i picked up from Tyler a while back for this 91 engine, for my 84. Te original plan is working out! lol
ACTUALLY. Anyone know of anyone selling a complete AAZ head setup? IE. right off a running vehicle? everything included.
Reply #1April 10, 2011, 11:49:49 am
Re: AAZ head on an NA? :D
« Reply #1 on: April 10, 2011, 11:49:49 am »
I figured. :( OK. Well I guess I need to find either a full 1.6td head, or a full 1.9td head :) I think this baby wants boost :D
Reply #2April 10, 2011, 11:53:13 am
« Reply #2 on: April 10, 2011, 11:53:13 am »
you dont need a turbo head to run boost..
i thought you already had an AAZ head? why do you need to find another?
Reply #3April 10, 2011, 12:01:48 pm
« Reply #3 on: April 10, 2011, 12:01:48 pm »
I think the AAZ head will be just fine on the NA. Yes, it will bolt right on with nothing funny on a hydraulic 1.6.
You may see some gains on the highway, both mileage and performance. However, the lower velocity of the air entering the cylinders may actually have a negative effect as Andrew mentioned.
I say give it a go and report back :)
Reply #4April 10, 2011, 12:17:47 pm
« Reply #4 on: April 10, 2011, 12:17:47 pm »
I know I dont need a turbo head, or a turbo block. If i turbo it I want to swap on a head with everything on it. Manifolds, turbo, etc. Makes life easier and probably cheaper. Plus the head Tyler gave me is a little rough, so i dont know if its even usable.. he donated it to a good cause lol
Hmm, generally porting naturally aspirated engines (in the gasser world) is a desired thing.. any reason it isn't so on our diesels?
Reply #5April 10, 2011, 12:27:22 pm
« Reply #5 on: April 10, 2011, 12:27:22 pm »
but, over porting a gasser engine is a bad thing.. and an AAZ head on a n/a, that would probably be the equivalent of an over-ported head.
if the air is going too slow, it doesnt fill the cylinder as well.. the velocity of the air actually kinda "rams" some air into the cylinder..
Reply #6April 10, 2011, 12:40:29 pm
« Reply #6 on: April 10, 2011, 12:40:29 pm »
I ported the head on my 1.9NA and while I can't draw any accurate conclusions because I changed so much at once, I think it was well worth the effort.
What intake manifold were you planning on running?
Reply #7April 10, 2011, 12:43:04 pm
« Reply #7 on: April 10, 2011, 12:43:04 pm »
1Y would work good if your not gonna boost it. would work better if you do boost it tho. lol.
Reply #8April 10, 2011, 08:08:05 pm
« Reply #8 on: April 10, 2011, 08:08:05 pm »
Tyler, I was thinking of running the manifold off my 8v gasser, and the exhaust off whichever looks the least restrictive. However I think the mk1 diesel intake has longer runners... might use it.
« Last Edit: April 10, 2011, 08:16:09 pm by 8v-of-fury »
Reply #9April 11, 2011, 12:05:52 pm
« Reply #9 on: April 11, 2011, 12:05:52 pm »
oval port manifold matched up to a D port head will not flow good. the D port intake (1Y) will flow better being that its matched to the head.
Reply #10April 11, 2011, 08:53:27 pm
« Reply #10 on: April 11, 2011, 08:53:27 pm »
I like the idea of the 1Y.. But I dunno of how easy it will be to come by.. ALSO if things go to plan I'll be driving a TDI in less than 40 days. And this will be back burnered.. And probably just a HG done lol
Fixmyvw.com
