Author Topic: 1.6TD vs 1.9TD rpm's?  (Read 4180 times)
January 20, 2006, 03:59:49 pm
Laurentian
« on: January 20, 2006, 03:59:49 pm »
Finally getting on track with my 1.9TD,
Wingman will be taking care of me.
I have seen numerous comments here about 1.9's not
being rev happy like the 1.6's.
However on my local Quebec site ( VWQebec ) I have not
come across this comment.
What's the situation on this, please set me straight!
Hope I have chosen the right motor, have big plans for it!
Thanks in advance,
Hugh
Reply #1January 20, 2006, 05:28:29 pm
935racer
« Reply #1 on: January 20, 2006, 05:28:29 pm »
The 1.9's do not like to rev like the 1.6's do. I can verify this as I have modified a bunch of both. There are several reasons the 1.9 doesn not rev:
1: crank is 2lbs heavier than the 1.6 crank, and that 2 lbs is on the very end of the counterweights so the reciprocating mass is signifigantly more.
2: The rod caps weigh double of what the 1.6 ones weigh.
3: The 1.9 crank has a longer stroke than the 1.6 crank.
4: The 1.9 flywheel is heavier.
5: The tiny turbo on the 1.9 runs out of breath really quick.
6: The 1.9 lda boost pin has little taper and thus creates very little additional fuel when compared to a 1.6 version.
There are other things too that I am forgetting.
Reply #2January 20, 2006, 07:30:26 pm
Cheesetoast
  • 285
« Reply #2 on: January 20, 2006, 07:30:26 pm »
all of those things sound like they can be changed/upgraded on the 1.9, if you were to lighten the 1.9 internals, how much power do you think there is to be gained and what would the costs be?
Reply #3January 21, 2006, 06:32:55 am
Laurentian
« Reply #3 on: January 21, 2006, 06:32:55 am »
Thanks for the clear reply!
I have a K-24 that I will be rebuilding soon with the intention
of installing on the 1.9TD.
I was also planning on some Smog GTD injectors and pump mods.
935Racer I also see you have a high perforomance cam advertised on your PassengerPerf. website.
Would this be worthwhile combined with a big downpipe plus
the other mods I mentioned?
I will not be playing around with the core other than the TDI
pully mod, heavy duty head studs and a better clutch.
Thanks for the help!
Hugh
Reply #4January 22, 2006, 01:36:34 pm
935racer
« Reply #4 on: January 22, 2006, 01:36:34 pm »
I don't think there is too much to be gained from lightening the bottom end of the 1.9 until someone can solve the high rpm fueling issue. I can't get a diesel to smoke after I flow a head, which is nice as far as no smoke go's but lame as far as I know if I could get more fuel there would be soo much more power.
Reply #5January 29, 2006, 07:01:27 am
Laurentian
« Reply #5 on: January 29, 2006, 07:01:27 am »
What could I expect performance wise with the following mods I intend to do before the swap?
Gilles performance pump rebuild
Smog's injectors
Large downpipe / exhaust with K24 turbo
Passenger perormance ported head
Intercooler
( and of course better clutch, head studs, TDI crank pully mod )
Thanks!
Reply #6January 29, 2006, 02:41:59 pm
935racer
« Reply #6 on: January 29, 2006, 02:41:59 pm »
Around 150WHP :twisted:
Reply #7January 30, 2006, 07:11:52 am
Laurentian
« Reply #7 on: January 30, 2006, 07:11:52 am »
Thanks Dave, who needs a GTI with those numbers 8)
Would the cam be money well spent?
Reply #8January 30, 2006, 08:28:46 am
HP
  • 225
« Reply #8 on: January 30, 2006, 08:28:46 am »
Quote from: "935racer"
And what about reliabiliy/duration??
What reinforcement mods to be done in order to sustain all that power?
