Author Topic: 81 Jetta D fuse panel info/wiring diagram needed  (Read 8375 times)
April 06, 2011, 10:01:08 am
« on: April 06, 2011, 10:01:08 am »
did 81 jettas (diesel) get the old style fuse panel with the old ceramic fuses?
im used to everything 81 or newer having the plastic blade fuses, and the fuse panel should have 2 rows of relays..
this one has an old style fuse box in it, with one row of relays in the fuse panel, and one row of relays clipped on top of the panel.
the car in question is a 12/81 Jetta D
and would anyone know where a wiring diagram is to be found?
Reply #1April 06, 2011, 06:56:33 pm
Re: 81 Jetta D fuse panel info/wiring diagram needed
« Reply #1 on: April 06, 2011, 06:56:33 pm »
the bently has the correct wiring diagram, and yeah it has the older style fuse panel, i can still get them new actually.
Reply #2April 07, 2011, 11:41:53 am
the_mad_rabbit
  • 6
« Reply #2 on: April 07, 2011, 11:41:53 am »
So, what does Slot J and L (#1/#3 relay location) do/what is it used for?
-AJ
"Life is like a bad margarita with good tequila, I thought as I poured whiskey onto my granola and faced a new day"
Lurker
Reply #3April 07, 2011, 11:59:17 am
« Reply #3 on: April 07, 2011, 11:59:17 am »
-AJ
it appears that they are not used...
and it looks like you have a fuel pump relay in slot L..
ive never seen a relay with a fuse on a diesel car before.. just on the gasser cars..
« Last Edit: April 07, 2011, 12:02:12 pm by R.O.R-2.0 »
Reply #4April 07, 2011, 12:39:31 pm
the_mad_rabbit
  • 6
« Reply #4 on: April 07, 2011, 12:39:31 pm »
Confirms my suspicions. Someone swapped out the diesel fuse pannel with a gasser one. Direct replacement, functions exactly the same way.
-AJ
Lurker
Reply #5April 07, 2011, 12:46:46 pm
« Reply #5 on: April 07, 2011, 12:46:46 pm »
-AJ
bingo.. we figured it out.
Reply #6April 07, 2011, 09:02:48 pm
Powered by Spearco
  • 1203
« Reply #6 on: April 07, 2011, 09:02:48 pm »
I've seen the elusive '80 Jetta diesel that has the early style fuse box like those but yours is not an '80 Jetta.
Whats wrong with that one. As longas its been swaped out correctly.
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
Reply #7April 07, 2011, 09:53:06 pm
lovinthedeez
  • 489
« Reply #7 on: April 07, 2011, 09:53:06 pm »
ohhh kev....one of MY favorite threads ;D
http://www.vwdiesel.net/forum/index.php?topic=25025.0
Reply #8April 08, 2011, 07:59:22 am
« Reply #8 on: April 08, 2011, 07:59:22 am »
no thinks dude.. i dont like that much wiring..
this thread is for The Mad Rabbit anyways, i just started it for him..
Reply #9April 08, 2011, 08:47:50 am
« Reply #9 on: April 08, 2011, 08:47:50 am »
my car is an 81 and came with the fuse box above
Reply #10April 08, 2011, 08:57:19 am
« Reply #10 on: April 08, 2011, 08:57:19 am »
the one Brian was talking about, or the one you posted a picture of?
Reply #11April 08, 2011, 12:10:28 pm
« Reply #11 on: April 08, 2011, 12:10:28 pm »
german cars (jetta/cabby) thru 82 has ceramic fused fuse boxes.. 83 went to ce1...
westy went to crappy set up in 81 and had their own unique box till moved to mexico in 88... then some had ce1.. then by 89 i think all had ce2.. till mk4..
Reply #12April 17, 2011, 06:50:00 am
« Reply #12 on: April 17, 2011, 06:50:00 am »
the one i put a picture up of, that is the one in my jetta
