Author Topic: AAZ to TDI?  (Read 13375 times)
April 04, 2011, 06:11:06 pm
jasonsansfleece
  • 162
AAZ to TDI?
« on: April 04, 2011, 06:11:06 pm »
Is it possible to put TDI pistons in an AAZ block and use a TDI head for a M-TDI build?
I think I've read threads to that effect but cant find them.
It not to easy to buy a complete TDI engine and transmission in the USA. When you find one for sale its a thousand miles away and several thousand dollars.
Then to install it in a mk2 you have motor mounts, shifter cables and clutch control to deal with.
I'm not going to include fuel delivery or VNT control under "problems" :)
An AAZ with a 020 transmission will fit right in and heads, pistons and other parts are easier to find and ship.
So how flawed is my thinking? The 020 might be a weak link. Is the AAZ bottom end/rods comparable with an AHU/AHL bottom strength wise ?
Any insights or thoughts? Links in this site?
Reply #1April 04, 2011, 06:32:32 pm
rallydiesel
  • 1880
Re: AAZ to TDI?
« Reply #1 on: April 04, 2011, 06:32:32 pm »
Yes you are right. An AAZ block and AHU/1Z block are basically the same. The ALH is quite a bit different though. You just need the AHU (or the stronger ALH) pistons. You should probably upgrade to a tdi crank gear too if you haven't already. Then a complete AHU head, injection pump and ecu with instrument cluster and you are good to go.
Search jimfoo for a thread on making a tdi out of an AAZ. He made his into an m-tdi and avoided the electronics/immobilizer issues.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #2April 04, 2011, 07:01:56 pm
jasonsansfleece
  • 162
Re: AAZ to TDI?
« Reply #2 on: April 04, 2011, 07:01:56 pm »
Well, M-TDI is the route I would want to take.
An AHU head and AHL pistons.
I will check out Jimfoos post. Funny how people make hundreds of posts then just disappear. I wonder if internet forums will have twenty five year reunions?
Reply #3April 04, 2011, 07:16:30 pm
jasonsansfleece
  • 162
Re: AAZ to TDI?
« Reply #3 on: April 04, 2011, 07:16:30 pm »
Reply #4April 04, 2011, 07:56:28 pm
blackdogvan
  • 574
Re: AAZ to TDI?
« Reply #4 on: April 04, 2011, 07:56:28 pm »
I have an AAZ based mtdi, its great. Its really pretty plug & play with the 1st gen tdi parts into the AAZ block. Search out Frank06 on tdiclub for a rebuilt AHU/1Z head & injectors.  You can ask for a set with a broken electrical lead on the 3rd injector since you are talking mTDI; makes things easier & a bit cheaper.
MikeW here for Nural tdi pistons & you're almost done.
About the only strange thing I came across is the need for a 3 hole MLS gasket with the type of pistons I used & the AAZ rods.
I'd say the AAZ crank & rods are more than up to snuff for a medium tune & 20 psi of boost. Whats your power goal?
What are you planning for a pump?
1991 Vanagon 1.9 mTDI
Reply #5April 05, 2011, 03:23:49 am
jasonsansfleece
  • 162
Re: AAZ to TDI?
« Reply #5 on: April 05, 2011, 03:23:49 am »
Blackdogvan, did you use AHU pistons. Any difference between them and ALH?
Would 200hp be unreasonable? With some upgraded manifolds and a VNT.
As to the pump, I have no plans at this point. I'm open to sugestions.
I do have a Giles pump on my 1.6td and no doubt he could build a fine M-TDI pump.
What about the 020 transmission? Are they up for 200hp?
Reply #6April 05, 2011, 05:46:13 am
Re: AAZ to TDI?
« Reply #6 on: April 05, 2011, 05:46:13 am »
The AAZ block is not the same as the AHU/1Z block and WILL NOT work if you are planning on building an electronic TDI. You may be able to have the block machined, but I have never heard of this being done.
I understand that the OP wants mTDI, and the AAZ block will work fine for that. I am just stating this for search purposes.
Reply #7April 05, 2011, 08:04:07 am
blackdogvan
  • 574
Re: AAZ to TDI?
« Reply #7 on: April 05, 2011, 08:04:07 am »
Burn, besides the crank position sensor boss on the AHU/1Z block I'm not aware of any other differences though, correct? For search purposes that post could lead people off track without some details on the differences.
@ jason I wouldn't build 200hp into any stock VE pump TDI engine without a cryo treated crank, crank girdle, h-beam rods, ARP2000 head studs, main studs, Rod studs, ceramic coated pistons not to mention the massive turbo pushing 40+psi required & a heavily modded 12mm injection pump, huge nozzles, custom clutch, axles umm basically everything. Thats full fire breathing race prepped tdi & likely not very street drivable. It'd be a fun build to watch tho. The AAZ bits will not work for that.
There is a thread on TDI club where a guy got his 1Z to 197hp/300ftlb. Crazy build.
140hp & 240ftlb would be fine though IHMO as long as you didn't try to ram boost down its throat at too low RPM.
Reply #8April 05, 2011, 08:24:08 am
rallydiesel
  • 1880
Re: AAZ to TDI?
« Reply #8 on: April 05, 2011, 08:24:08 am »
I forgot about the crank sensor boss. Thanks for pointing that out.
Reply #9April 05, 2011, 09:17:54 am
Re: AAZ to TDI?
« Reply #9 on: April 05, 2011, 09:17:54 am »
Good point and yes, AFAIK that is the only difference.
Reply #10April 05, 2011, 09:34:57 am
blackdogvan
  • 574
Re: AAZ to TDI?
« Reply #10 on: April 05, 2011, 09:34:57 am »
I was hypothetically wondering the other day about what i'd have to do to go E. Could you bodge a crank position sensor onto a block?
Reply #11April 05, 2011, 09:35:59 am
Re: AAZ to TDI?
« Reply #11 on: April 05, 2011, 09:35:59 am »
its gotta read off the reluctor ring on the end of the crank.. it cant just be bodged in somewhere..
Reply #12April 05, 2011, 10:00:53 am
blackdogvan
  • 574
Re: AAZ to TDI?
« Reply #12 on: April 05, 2011, 10:00:53 am »
If I can be so bold as to point out a trend in your posts without setting off a war; you could offer more info in many of them. Saying you can't do something or you don't need to do that isn't really helpful without adding why it doesn't work, how it could work or why you don't need that.
So here for example, how could a crank position sensor be added to a AAZ block? Obviously it can't just go anywhere, or could it as long as it kicks at TDC?
Or could you use the 16v euro crank position sensor/main seal? PN 036 105 189 C
I wonder if you could use that to run a tach signal on a Mtdi...
Reply #13April 05, 2011, 10:04:07 am
rallydiesel
  • 1880
Re: AAZ to TDI?
« Reply #13 on: April 05, 2011, 10:04:07 am »
I think that someone like Mark Malone would be the one to ask. Possibly he could adapt the gasser crank signal to work with a tdi ecu but I really don't know anything about programming ecu's so maybe I'm way off base.
Reply #14April 05, 2011, 10:42:52 am
Re: AAZ to TDI?
« Reply #14 on: April 05, 2011, 10:42:52 am »
damn, all i said was that it needs to read from an exact place to see the reluctor ring..
im not used to all those EURO BS parts.. there not easily available in the us, and sure as hell never came stock on anything in the US.
sorry, i was taught to ask questions.. and leaving an answer kinda vague, that prompts people to ask questions, and dig deeper than they would if someone just layed it out for them.
whatever tho, if you dont like my posts, you should ignore them..
and rest assured, im calm when typing this, no hard feelings.
its basically pointless to be arguing about a crank sensor tho.. i doubt someone is going to build a FULL TDI out of an AAZ.. only ones ive seen, were turned into mechanical.
