Author Topic: Year of filter change  (Read 3423 times)
March 31, 2011, 03:05:57 pm
  • 1739
« on: March 31, 2011, 03:05:57 pm »
Which year did VW change to the fuel filters with the return valve. I don't remember if it was 87, 88? I'm pretty sure 85 and 86 had the simple fuel in/out with the bleeder on top.
Reply #1March 31, 2011, 11:17:16 pm
Baron VonZeppelin
Re: Year of filter change
« Reply #1 on: March 31, 2011, 11:17:16 pm »
I'm pretty sure it was 88.
i KNOW 89 had the thermo T deal for sure.
I keep 4 of them serviced.
If its critical - you might could check applications on AhausAZ.
I've been converting them all back to 85-87 style.
Tested 3 of those plastic thermo T's by putting them in the freezer for a while then bench testing them. And none have worked so far. Will probably be testing #4 soon.
Supposed to divert fuel from pump back into filter - until warmed up. If they worked, i'd leave them in place.
Reply #2April 01, 2011, 06:28:47 am
  • 1739
« Reply #2 on: April 01, 2011, 06:28:47 am »
It's because when i've done VO conversions, i delete it so VO doesn't return to the dedicated diesel filter and gel up when cold, letting the engine start but then stall 3 minutes down the road. I know which filters to get [the older simple in/out] but need to tell someone who is buying my truck which ones to buy in the future.
