Author Topic: Clutch cable mix and match?  (Read 4520 times)
March 27, 2011, 05:28:33 am
Patrick
  • 1034
« on: March 27, 2011, 05:28:33 am »
Got a bad cable on a '92(mk2) jetta (self adjusted too tight and can't get it to back off). Can't get a new one on a sunday. Anyone know if the cable in a mk3 will fit? Part numbers are different. Transmission end of the cable looks the same, before I crawl under the steering wheel and try to get one out, is the clutch pedal end the same?
Reply #1March 27, 2011, 09:32:39 am
Re: Clutch cable mix and match?
« Reply #1 on: March 27, 2011, 09:32:39 am »
mk3 has a ball on the pedal end
mk2 has a hook on the end.
they DO NOT interchange at all..
turn your self adjusting one upside down, and tap the sides of it and work it till it loosens again. they usually always do, just gotta mess with it a bit..
Reply #2March 27, 2011, 04:02:41 pm
Patrick
  • 1034
« Reply #2 on: March 27, 2011, 04:02:41 pm »
Thanks for the tip. I just went out and flipped up the one in the doner car, shoved it together and caged it. Now if it wasn't so cold I'd install it! :D
Reply #3March 27, 2011, 06:15:17 pm
« Reply #3 on: March 27, 2011, 06:15:17 pm »
like i say, work at the one in your car for a second, disconnect it and turn it upside down, sideways, upright, and just keep working it, they release 99% of the time..
Reply #4March 28, 2011, 01:55:49 am
smutts
  • 720
    ClackClackClackClackClack
« Reply #4 on: March 28, 2011, 01:55:49 am »
Self adjusting clutch cables...........Horrible vile things. >:(
Reply #5March 28, 2011, 03:18:16 am
Patrick
  • 1034
« Reply #5 on: March 28, 2011, 03:18:16 am »
Went out last night and installed the one from the doner car. Worked fine. Played with the other one for a bit, could probably make it work too. No little plastic tie built in to the cable to cage it though. It will go on the shelf, would work in a pinch. Have to get around to some pictures of this project....
