Author Topic: FS Turbo and diesel stuff - No TDI  (Read 12526 times)
March 18, 2011, 07:30:47 am
« on: March 18, 2011, 07:30:47 am »
Please IM me with inquiries
I'm clearing out the garage. Everything's gotta go.
1- set of TD injectors. unknown condition - $20
2a- Boost hose - T3 and K24 - $5
2b- Boost hose - K03 - $5 sold
2c-  Boost hose - k03 - $5 sold
3- K03 - good bit of in and out, lots of up and down. Probably only a core - $25 sold
4- AAZ intake manifold - $45 sold
5- Exhaust manifold - $40
Pictures of above items
http://img.photobucket.com/albums/v603/burnyourmoney/DSC09786.jpg
6a- TD valve cover - $5 sold
6b- TD valve cover - covered in silicon, might be bent- $5
6c- TD valve cover - one hole is drilled out to an oversize -$5
http://img.photobucket.com/albums/v603/burnyourmoney/DSC09784.jpg
7a- MK2 intake hose - $20 sold
7b- MK2 intake hose - $20 sold
8- 1.6TD intake manifold - $40 sold
Picture of above items
http://img.photobucket.com/albums/v603/burnyourmoney/DSC09783.jpg
9- mk1 passenger motor mount bracket - $10
10- Stock TD oil cooler with 1 coolant hose - $5 sold
11- TD oil filter flange - $10 sold
12- 1.6 IM shaft pulley with lip - $10
13a- Exhaust manifold - $40 sold
13b- Exhaust manifold - $40 sold
14- 1.6TD injection lines - some rust on the ends. Should be cleaned out before use - $25
15- AAZ block breather hose - $5 sold
16a- 1.6TD breather hose - $5 sold
16b- 1.6TD breather hose - $5 sold
16c- AAZ breather hose - $5 sold
17a- Boost hose (T3 K24) - $5 sold
17b- Boost hose (T3 K24) - $5
18a- 4 turbo bolts (not K03)- $5
18b- 4 turbo bolts (not K03)- $5 sold
http://img.photobucket.com/albums/v603/burnyourmoney/DSC09782.jpg
19 - Top piece of TD intake manifold - $5 sold
20 - K03 wastegate - $5 sold
21 - metal oil cap -great for polishing - $5
22 - Metal coolant flanges plus water pump flange - $25 sold
23 - Tranny bellhousing for finding TDC - $10 sold
24 - turbo oil drain line (K03 I think) - $25 sold
25 - AAZ injection lines - $20 sold
26 - MK1 dual outlet exhaust manifold - missing 1 stud - $15
http://img.photobucket.com/albums/v603/burnyourmoney/DSC09781.jpg
27 - Brand new MC - Mk3 - $35
http://img.photobucket.com/albums/v603/burnyourmoney/DSC09769.jpg
28 - 4 Rabbit mudflaps - $35 sold
http://img.photobucket.com/albums/v603/burnyourmoney/DSC09767-1.jpg
http://img.photobucket.com/albums/v603/burnyourmoney/DSC09768-2.jpg
29a - 1.6TD oil fed line - $10 sold
29b - 1.6TD oil fed line - $10 sold
29c - 1.6TD oil fed line - $10 sold
http://img.photobucket.com/albums/v603/burnyourmoney/DSC09766.jpg
30 - 1.6TD intake manifold - $40 sold
http://img.photobucket.com/albums/v603/burnyourmoney/DSC09765.jpg
http://img.photobucket.com/albums/v603/burnyourmoney/DSC09764-1.jpg
31a - 1.6 Vacuum pump - $20 sold
31b - 1.6 Vacuum pump - $20 sold
http://img.photobucket.com/albums/v603/burnyourmoney/DSC09763.jpg
32 - K03 Intake hose - $5 sold
http://img.photobucket.com/albums/v603/burnyourmoney/DSC09761.jpg
33 - Intercooler - $30 sold
http://img.photobucket.com/albums/v603/burnyourmoney/DSC09760.jpg
http://img.photobucket.com/albums/v603/burnyourmoney/DSC09759.jpg
« Last Edit: April 10, 2011, 08:56:36 am by burn_your_money »
Reply #1March 18, 2011, 08:23:19 am
Re: FS Turbo and diesel stuff - No TDI
« Reply #1 on: March 18, 2011, 08:23:19 am »
I'll take 23 the bell housing... will send you a PM.
Reply #2March 18, 2011, 11:06:13 am
81 Caddy
« Reply #2 on: March 18, 2011, 11:06:13 am »
I can use 31b. How much sent to 92021?
thanks, Nick
Reply #3March 18, 2011, 11:33:03 am
BlastIt
  • 66
    • bigrblasting.com
« Reply #3 on: March 18, 2011, 11:33:03 am »
Sent you a PM
Reply #4March 22, 2011, 05:16:55 pm
« Reply #4 on: March 22, 2011, 05:16:55 pm »
up we go
Reply #5March 22, 2011, 06:22:13 pm
« Reply #5 on: March 22, 2011, 06:22:13 pm »
i want the aaz block breather hose and aaz injection lines pm me
Reply #6March 22, 2011, 07:18:07 pm
mystery3
  • 774
« Reply #6 on: March 22, 2011, 07:18:07 pm »
I need this: 11- TD oil filter flange - $10
Shipping to California might not be worth it but if you can provide a shipped price to 94086 that would be great.
Reply #7March 23, 2011, 05:02:06 pm
shwak23
  • 417
    • Blackdog Junkyard
« Reply #7 on: March 23, 2011, 05:02:06 pm »
I need the injector hard line that goes to cylinder 3 I think... The second one from the right.
Reply #8March 23, 2011, 07:40:07 pm
« Reply #8 on: March 23, 2011, 07:40:07 pm »
Injection lines are sold as a set only, sorry
Reply #9March 23, 2011, 08:14:41 pm
« Reply #9 on: March 23, 2011, 08:14:41 pm »
on that intercooler, whats the little fitting for on the bottom left?
Reply #10March 24, 2011, 07:26:11 am
« Reply #10 on: March 24, 2011, 07:26:11 am »
I`m not sure. I think it is connected to the charge air but I would have to double check.
Reply #11March 24, 2011, 07:40:54 am
« Reply #11 on: March 24, 2011, 07:40:54 am »
Totally interested in it BtW :)
Reply #12March 24, 2011, 10:31:45 am
« Reply #12 on: March 24, 2011, 10:31:45 am »
prolly for a map sensor or something..
Reply #13March 25, 2011, 07:42:47 am
chopper03
  • 42
« Reply #13 on: March 25, 2011, 07:42:47 am »
You, sir have a PM. :)
Reply #14March 27, 2011, 11:24:43 am
dodger21
  • 97
« Reply #14 on: March 27, 2011, 11:24:43 am »
How much for shipping on the MK3 MC? Stateside to 61021 zip code?
1985 Golf 1.6NA with a 5spd
