Author Topic: Diesel knock? - NOW FIXED!!!!!!!  (Read 107640 times)
Reply #15March 16, 2011, 05:18:58 pm
Mark(The Miser)UK
  • 1557
Re: Diesel knock?
« Reply #15 on: March 16, 2011, 05:18:58 pm »
I sold an engine to a friend for his caddy and gave him help setting it up.
It knocks quite heavily  ::)
I changed the pump timing and still the knock remained, I even swung the pump across it's timing limits while the engine was running - no real change.
He swapped the injectors for known good ones - still knocking.
Fearing the worst I missed out on Sunday lie in and was down at his garage early, I pulled the head - very clean, slight carbon build up on number 3 but as expected.
Now pulled the sump, nothing in the oil, dropped the connecting rod caps and pulled the pistons out to check
Still nothing  ???
It's not lifters as it's not 'that' type of ticky noise, it's more clack.
Any ideas people? It starts and runs fine. Just noisy.
It can only be pump now surely?
It could be the valves kissing the pistons, or getting very close to them.
Nearest point is not TDC  but a little either side, as the piston chases the exhaust valve before it closes BTDC and as the inlet chases the piston ATDC.
The sound echoes out the manifolds. Worsened  by skimming of head, naturally...
My engine has been doing it for 30,000miles :-[
Mark-The-Miser-UK
Reply #16March 16, 2011, 09:52:47 pm
  • 2932
Re: Diesel knock?
« Reply #16 on: March 16, 2011, 09:52:47 pm »
Rod pins feel sloppy in the pistons?
Reply #17March 17, 2011, 03:16:09 pm
regcheeseman
  • 714
Re: Diesel knock?
« Reply #17 on: March 17, 2011, 03:16:09 pm »
Gudgeon pins and small ends are fine - that was my no1 suspect after timing and injectors were eliminated.
I'd expect to see some witness marks - there is nothing
No 2 piston has a little dent on one edge, looks like something solid entered the chamber made two dents before being spat out, there's a corresponding mark on the cylinder wall - but no damage, not significant.
Reply #18March 17, 2011, 09:14:26 pm
maxfax
  • 2126
Re: Diesel knock?
« Reply #18 on: March 17, 2011, 09:14:26 pm »
Off the wall question, is this engine hydro or mech lifter???
Reply #19March 18, 2011, 02:23:11 am
Mark(The Miser)UK
  • 1557
Re: Diesel knock?
« Reply #19 on: March 18, 2011, 02:23:11 am »
Still nothing  ???
Reg,
If you can take the vehicle out for a drive, then on a quiet stretch [might still be one in Devon way]with the clacking happening, turn off the engine, whilst still in gear and see if the sound disappears, if it goes, then its fuel, if it doesn't then it's 'mech'
;D
Mark-The-Miser-UK
Reply #20March 18, 2011, 05:16:52 am
regcheeseman
  • 714
Re: Diesel knock?
« Reply #20 on: March 18, 2011, 05:16:52 am »
hydro
Mark/Blackdogvan
I'll try that test when it's rebuilt, the workshop is right next to the only real dual carriageway in North Devon. A well known test strip.
Reply #21March 18, 2011, 09:21:35 am
sdwarf36
  • 159
Re: Diesel knock?
« Reply #21 on: March 18, 2011, 09:21:35 am »
If you crack the fuel lines one at a time, you will take the load off that cylinder( no fuel= no fire=no load) -you can see if the noise changes.
 To check for the flywheel bolts, put the car in gear-have someone stand hard on the brakes-and go back+ forth with the crank bolt. Look to see if the flywheel moves the same amount as the crank bolt.
 Also-are #1+4 piston up the same amount? (just thinking possible prior bent rod)
91 Jetta on WVO na / td swap in progress.
 "VW happiness is having 4 working door handles."
Reply #22March 18, 2011, 03:34:34 pm
regcheeseman
  • 714
Re: Diesel knock?
« Reply #22 on: March 18, 2011, 03:34:34 pm »
Rods are fine, already done the injector test before tearing the motor down.
I'll do the flywheel test.
Reply #23March 18, 2011, 11:21:38 pm
rdezsofi
  • 19
Re: Diesel knock?
« Reply #23 on: March 18, 2011, 11:21:38 pm »
I guess you have it torn apart.....how are this pistons and bore, as far as measurements? I'm thinking severe piston slap maybe??? Did you do a compression check prior to teardown? It might just have extremely high compression. (Head surfaced, etc, etc.)
Reply #24March 19, 2011, 02:26:50 am
Mark(The Miser)UK
  • 1557
Re: Diesel knock?
« Reply #24 on: March 19, 2011, 02:26:50 am »
hydro
Mark/Blackdogvan
Hi,
 I'd just like to apologise to Blackdog van , I didn't  spot his [I assume a chap :o] prior post detailing similar technique. ::)
"I must read the threads more closely  I must read...."
In my defence, my technique removes even more fuel ;D
Mark-The-Miser-UK
Reply #25May 24, 2011, 12:45:25 am
regcheeseman
  • 714
Re: Diesel knock?
« Reply #25 on: May 24, 2011, 12:45:25 am »
It's got me beat! looks like the turbo seal is giving up the game too.
We're going to fit another engine and this one will get an autopsy at some point.
Reply #26May 24, 2011, 02:23:39 am
Mark(The Miser)UK
  • 1557
Re: Diesel knock?
« Reply #26 on: May 24, 2011, 02:23:39 am »
Don't you hate that.
I'm thinking my only solution in my case is to remove the 'unleaking head' and skim the outer exhaust valves.
I too had bought small end and big end bearings, expecting[hoping] to find a rogue one; but no play detected so the kits remain in reserve.
Did the sound continue with no fuelling?
Mark-The-Miser-UK
Reply #27May 25, 2011, 05:34:41 am
carrizog60
  • 978
Re: Diesel knock?
« Reply #27 on: May 25, 2011, 05:34:41 am »
my aaz(well 1y with turbo) is now making a tim tim tim sound,not clatter...
not to highjack the thread sorry but can anyone help?
timed to 1.00mm,with aaz injectors and 1.6 gtd fuel pump
Portugal
Reply #28May 26, 2011, 02:43:02 am
regcheeseman
  • 714
Re: Diesel knock?
« Reply #28 on: May 26, 2011, 02:43:02 am »
FIXED IT  ;D
I can't take any credit for doing so, it was only spotted by a mechanic who had a Toyota Hilux doing similar.
Basically despite have the injector lines and pump removed at least four times, no-one noticed that they were wrong.
The previous owner had managed to bend them to fit in a different sequence. They didn't look obviously bent and offered themselves up to the head quite naturally.
A quick switch around and it's running sweet as!
It's surprising that it started, idled and run quite happily in it's mixed up state.
« Last Edit: May 26, 2011, 02:49:46 am by regcheeseman »
Reply #29May 26, 2011, 03:05:09 am
macka
  • 957
Re: Diesel knock? - NOW FIXED!!!!!!!
« Reply #29 on: May 26, 2011, 03:05:09 am »
well its fixed and all is well. That is funny that it ran
Quote from: Vincent Walden
I do know that I drive torque,  while listening to my friends prattle on about horsepower.
