General Information
General
Oil Pressure/Oil temp install questions
Topic: Oil Pressure/Oil temp install questions (Read 4202 times)
March 10, 2011, 10:10:54 am
gitkrunk
User+
March 10, 2011, 10:10:54 am »
hey guys i am in the process of doing a 1.6 TD swap into my suzuki samurai and had few questions. I bought a angled oil filter plate from jeff at Acme. it has 2 holes in it. 1 for the sensor and 1 for the turbo.
The problem im running into is sensors =[ i want to install oil pressure and oil temp off that sensor hole. and run the factory idiot light to the one on the head.
does anyone know if there is a gallery plug i can put one sensor? or do i have to find a bunch of Tees and fittings to make it work?
I'm having a hard time finding a M10x1.0 to 1/8npt coupler. I think im gonna use the sunpro 1/8x1/8x1/8 tee
Thanks a lot.
March 10, 2011, 10:13:52 am
Re: Oil Pressure/Oil temp install questions
March 10, 2011, 10:13:52 am »
metric and NPT are the same thread pitch, one is just tapered (npt)
March 10, 2011, 10:19:37 am
gitkrunk
User+
March 10, 2011, 10:19:37 am »
so i can stick the 1/8 sensor in the hole? it felt a little tight after the first few threads and i didn't feel like forcing it any.
March 10, 2011, 11:32:20 am
March 10, 2011, 11:32:20 am »
it felt tight because its actually tightening up..
M10x1.0 (oil pressure sender thread size) and 1/8 npt are the same basic threads.
M10 is a straight thread. NPT is tapered threads..
so when you put tapered threads in a straight hole, it still tightens up and doesnt leak..
March 10, 2011, 01:10:03 pm
gitkrunk
User+
March 10, 2011, 01:10:03 pm »
cool. was a little nervous about forcing it.
March 11, 2011, 10:06:43 am
March 11, 2011, 10:06:43 am »
use teflon thread tape just because...
March 11, 2011, 12:32:25 pm
March 11, 2011, 12:32:25 pm »
Incidentally, I thought the VWs of our era that came with oil pressure gauges had the sending unit for it in the head.
I would think it gives a better indication of engine oil pressure than a spot right next to the oil pump.
March 11, 2011, 01:20:45 pm
mtrans
March 11, 2011, 01:20:45 pm »
R 1/8 9,73 -Outside diameter of outside thread
8,6 -Inside diameter of inside thread
28 -number THREAD in mm on 1"
M10X1 10 Outside diameter of outside thread
9,0 Inside diameter of inside thread
I am not shure but all R are conical,M are not
I`ll improve my English
March 12, 2011, 10:26:34 am
March 12, 2011, 10:26:34 am »
fyi.. cannot do temp sensor in a t... gotta have oil flow past it.. else it will not read temp right
so use the head with a t for both pressure aka light and gauge..
March 13, 2011, 11:00:51 am
gitkrunk
User+
March 13, 2011, 11:00:51 am »
CRSMP5 that makes sense. I think i will run Oil pressure off the filter adapter. and Oil temp off the one in/near the head ( i haven't seen my engine yet so i don't know where or what size and thread the hole is) unless you think it should be the other way around.
As far as the factory idiot light i just won't use. i figure will those 2 monitoring i won't need it.
thanks lots guys
Last Edit: March 13, 2011, 11:21:23 am by gitkrunk
March 13, 2011, 01:16:55 pm
March 13, 2011, 01:16:55 pm »
no.... oil no flow past one on head.. its at the end of a oil passage..
so fileter gets temp and head gets pressure.. and if you spend extra on the gauge sender for pressure you can buy one with a idiot light sensor built in..
General Information
General
