Author Topic: Oil cooler ( warmer ) 90 IDI  (Read 3626 times)
March 10, 2011, 08:39:47 am
cervelorod
  • 41
« on: March 10, 2011, 08:39:47 am »
I recently purchased the stock oil cooler ( warmer ) for my IDI.  Can someone snap a good pic of yours so I can see how the hoses run.
Thanks,
Rod
1990 Jetta IDI - soon to be TD
Reply #1March 10, 2011, 08:42:37 am
Re: Oil cooler ( warmer ) 90 IDI
« Reply #1 on: March 10, 2011, 08:42:37 am »
you get the right hoses to hook it up? it takes 2 special hoses..
Reply #2March 10, 2011, 08:52:03 am
cervelorod
  • 41
« Reply #2 on: March 10, 2011, 08:52:03 am »
Any idea on year's that I can peruse the parts manual on?  Bentley won't be here for a few days..
Reply #3March 10, 2011, 08:57:45 am
« Reply #3 on: March 10, 2011, 08:57:45 am »
FWIW, the hose connections point right at the water pump.
the front nipple hooks into the hose that enters the center of the water pump..
the rear nipple connects into the top port.. the one that runs from the WP to the water neck on the front of the head..
Reply #4March 10, 2011, 01:57:18 pm
Bugsy_malone 666
  • 178
« Reply #4 on: March 10, 2011, 01:57:18 pm »
I had a bit of a question about this actually.
I have a 1600TD with one already hooked up and its linked into the head to water pump circuit, so I wondered if you didnt have the right hoses on the block, would it also be possible to just run it in the heating system loop after the heater matrix? as that goes back to the same point on the pump?
Reply #5March 11, 2011, 06:45:30 am
cervelorod
  • 41
« Reply #5 on: March 11, 2011, 06:45:30 am »
Bugsy - what year / model is yours on?  I want to order the official hoses but am having trouble finding the right ones online.  The parts guys want model and year to begin with...  The joy of living 90 miles from nowhere....
R
Reply #6March 11, 2011, 06:53:12 am
nathan_b
  • 361
« Reply #6 on: March 11, 2011, 06:53:12 am »
I think every td came with an oil cooler, right?
Reply #7March 11, 2011, 08:13:19 am
« Reply #7 on: March 11, 2011, 08:13:19 am »
every single TD, and lots of higher end gassers 8v's, all 16v's
you need the diesel specific hose from the wp-to-front water neck
if i were you tho, i would use the coolant distribution tubing off a mk2 gasser engine, it has 2 separate hoses to connect the oil cooler instead of one hard to get hose..
Reply #8March 11, 2011, 11:39:15 am
GEE-BEE
  • 1604
« Reply #8 on: March 11, 2011, 11:39:15 am »
I make them
028121053 Q
037122058
Silicone one piece design of course
not like that three piece china crap with the plastic center line that will fail
the original meyle german were one piece epdm rubber
to cut cost they went to the three piece hose with a plastic t
GB
« Last Edit: March 11, 2011, 04:42:09 pm by GEE-BEE »
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #9March 11, 2011, 01:55:39 pm
Bugsy_malone 666
  • 178
« Reply #9 on: March 11, 2011, 01:55:39 pm »
Even my N/A 1.6D has one!
My 1600TD was a 1987 Golf CL.
Anyone know what the answer is to my post earler in this thread about linking it into the heating loop instead of the normal one?
Reply #10March 11, 2011, 02:16:37 pm
« Reply #10 on: March 11, 2011, 02:16:37 pm »
well, thats a bit odd, ive never seen a factory VW n/a come with an oil cooler..
Reply #11March 11, 2011, 03:52:55 pm
Bugsy_malone 666
  • 178
« Reply #11 on: March 11, 2011, 03:52:55 pm »
Well it was an engine from a pickup then it was in a vanagon. its apparently a 1983 lump. The only thing I can guess is its either had one fitted because of being in a vanagon, or at some stage despite the engine numbers its actually been remanufactured to TD spec, but its got an NA pump, unless it was an eco diesel that some gues on here have talked about. Or maybe a european thing?
I know I havent seen any other D engines with it as standard.
Reply #12March 11, 2011, 04:45:44 pm
GEE-BEE
  • 1604
« Reply #12 on: March 11, 2011, 04:45:44 pm »
pump to oem cooler to head outlet ( upper)
pump to oem cooler to metal hardline to hose/ heater valve
GB
Giles Pump OHC
MK1 JETTA DASH
Reply #13March 12, 2011, 05:33:53 am
Bugsy_malone 666
  • 178
« Reply #13 on: March 12, 2011, 05:33:53 am »
GB
So basically what I was thinking, hose comes out end of head, goes into the heater matrix, comes out the other side of the heater matrix then down through a pipe to the oil cooler then from the cooler to the pump. normally I know what you mean there is a metal pipe that runs all the way down to the water pump with a short rubber hose.
Reply #14March 12, 2011, 08:42:22 am
« Reply #14 on: March 12, 2011, 08:42:22 am »
GB
there isnt enough flow thru the oil cooler. not all the coolant flow goes thru it either.. if you hooked it up to the heater lines, i dont think your heater would work that good anymore..
