Author Topic: Metal HD 1.6 sealing issue. Advice needed.  (Read 2238 times)
March 09, 2011, 06:06:38 pm
somepunk22
  • 79
« on: March 09, 2011, 06:06:38 pm »
I just fired up my TD tonight for the first time in several years. Fresh bottom end, reman head, ARP, and a 2 notch metal headgasket. I cut up a washer to seal the water jacket with some RTV. Everything torqued down to 100 ft/lbs. When running I have a small leak just to the passenger side of the oil drain near the extra water jacket that needs to be sealed up. The headgasket spec is 0.059". Tonight I found another washer which I believe is the same as the one I cut up for the seal, and it is exactly 0.059" thick. So do I torque higher to seal it up, or could I damage my head?
Reply #1March 09, 2011, 06:33:49 pm
Re: Metal HD 1.6 sealing issue. Advice needed.
« Reply #1 on: March 09, 2011, 06:33:49 pm »
I would not. 120 is about tops on the torque and you are short of that, but to compress the gasket to get the rubber to seal I think you are flirting with disaster. I would think it has probably shrank over the last few years of not running/oxidizing.
I used some teflon joint sealant to plug the hole I have. Holding great after 12,000.
Reply #2March 09, 2011, 06:36:41 pm
nathan_b
  • 361
« Reply #2 on: March 09, 2011, 06:36:41 pm »
headgaskets are meant to "squish." Washers are not. Make it smaller and try again.
Reply #3March 09, 2011, 06:48:40 pm
somepunk22
  • 79
« Reply #3 on: March 09, 2011, 06:48:40 pm »
This is why I stopped, but the MLS headgasket is much thicker then 0.059" before installation.
