Author Topic: No more coolant baths!  (Read 2974 times)
March 04, 2011, 05:53:11 pm
maxfax
  • 2126
« on: March 04, 2011, 05:53:11 pm »
I forget who posted about doing this to the W/P housing way back when, but I decided to one up it and do the T-stat housing too..   FINALLY I can drain the thing and quite possibly maybe hit a drain pan... Never have I been so excited at the thought of changing my thermostat...
Reply #1March 04, 2011, 07:31:19 pm
JGWarner
  • 77
Re: No more coolant baths!
« Reply #1 on: March 04, 2011, 07:31:19 pm »
THANK YOU for posting this just in time before I re-installed my WP. This is now on the mod list!
Reply #2March 04, 2011, 07:33:17 pm
« Reply #2 on: March 04, 2011, 07:33:17 pm »
Brass and Aluminum. I wouldn't worry, but maybe some teflon tape would do good on it.
Great mod, I will do on the next WP. Thanks
Reply #3March 04, 2011, 07:45:07 pm
mystery3
  • 774
« Reply #3 on: March 04, 2011, 07:45:07 pm »
The sensors have brass housings in aluminum from the factory so I wouldn't worry too much, then again maybe that's why most of the old thermostat housings are s corroded?
Reply #4March 04, 2011, 08:27:36 pm
maxfax
  • 2126
« Reply #4 on: March 04, 2011, 08:27:36 pm »
I used teflon tape on em..  If for no other reason a tad extra leak prevention...  I have no worries about the brass plugs..  I don't think I would use steel though... Aside from the corosion issues, I have visions of cranking the sucker in there too tight and breaking something..
 I did put a blob of weld on the t-stat housing just for a little extra meat to cut threads into..  I don;t think it was really necessary, but once again, extra insurance.....    I did consider using radiator petcocks in the holes, but I had fears of the darned things rattling open..
I believe credit goes to Fatmobile for the drain in the W/P housing....
Lucas, do you see the antiseize oozing from the t-stat bolts??   ;D
« Last Edit: March 04, 2011, 09:17:53 pm by maxfax »
Reply #5March 05, 2011, 05:07:38 am
macka
  • 957
« Reply #5 on: March 05, 2011, 05:07:38 am »
 ;D that was a gooder Max
Quote from: Vincent Walden
Reply #6March 05, 2011, 07:17:23 am
maxfax
  • 2126
« Reply #6 on: March 05, 2011, 07:17:23 am »
I plan on adding a block drain in my vanagon.  The engine is tipped over so much that there is a significant amount of coolant left in the block even after draining.
I guess the freeze plugs are high enough that some sort of drain in one of those wouldn't do it..  Will you be drilling and tapping the block?
Reply #7March 05, 2011, 08:47:48 am
« Reply #7 on: March 05, 2011, 08:47:48 am »
one on the soft plug side of the block? that makes really good sense..
