Author Topic: Pump question..  (Read 3996 times)
March 01, 2011, 08:15:09 am
TD100
  • 16
Pump question..
« on: March 01, 2011, 08:15:09 am »
 I've had a pump for some time now off a Land Rover 300 tdi and really need to get back on to this project. How can I remove the hub that mounted the timing sprocket to it? I assumed it was just pressed on and even after allowing it to soak for a day or two in PB Blast, it still will not come off. I've used a MAP torch as well as breaking off one of the jaws on my puller, nothing will budge. I am afraid to go any further for fear of damaging it. Just want to remove it so I can put on the sprocket off my 1Z.
 Thank you!
-Rich
 '93 Toyota T100. R150 5-speed, 1.6 w/ vnt15, inter cooled and 2.5" exhaust.
 http://www.geistsystems.com/
Reply #1March 01, 2011, 08:29:26 am
Re: Pump question..
« Reply #1 on: March 01, 2011, 08:29:26 am »
tap around the outside edge lightly wit ha hammer. lightly I have seen them shatter with too much force.
Reply #2March 01, 2011, 08:52:11 am
TD100
  • 16
Re: Pump question..
« Reply #2 on: March 01, 2011, 08:52:11 am »
 Thank you 8v, I will give that a try..
-Rich
Reply #3March 02, 2011, 09:29:13 am
Re: Pump question..
« Reply #3 on: March 02, 2011, 09:29:13 am »
if you use a puller again, hit the puller with a hammer, right on the end of it, inline with the shaft..
Reply #4March 06, 2011, 11:40:46 pm
galaboff
  • 60
Re: Pump question..
« Reply #4 on: March 06, 2011, 11:40:46 pm »
Yes, this is a good option..
Reply #5March 07, 2011, 02:03:31 pm
Re: Pump question..
« Reply #5 on: March 07, 2011, 02:03:31 pm »
just kinda tap it tho, dont beat the crap out of it trying to get it off.
sometimes they are on there SOO tight that they come off in 2 pieces..
