Author Topic: North America's First Turbo Diesel VW Fox  (Read 30124 times)
Reply #60June 24, 2011, 08:29:09 pm
JGWarner
  • 77
Re: North America's First Turbo Diesel VW Fox
« Reply #60 on: June 24, 2011, 08:29:09 pm »
Here's a video of the turbo shaft play.
http://www.youtube.com/embed/-yKPDm_9MBg
I think it will do just fine. Opinions?
« Last Edit: June 24, 2011, 08:30:59 pm by JGWarner »
Reply #61June 25, 2011, 05:41:56 am
« Reply #61 on: June 25, 2011, 05:41:56 am »
its a bit playful, but really spins nicely, looks good to go imo
Reply #62June 25, 2011, 07:13:41 am
JGWarner
  • 77
« Reply #62 on: June 25, 2011, 07:13:41 am »
It wiggles, but has absolutely no blade-to-housing contact, and spins freely. No in-and-out movement at all along the axis of the shaft.
Reply #63June 25, 2011, 09:27:26 am
vdubspeed
  • 191
« Reply #63 on: June 25, 2011, 09:27:26 am »
Reply #64June 25, 2011, 11:39:08 am
« Reply #64 on: June 25, 2011, 11:39:08 am »
Just for a heads up...I just placed this EGT/gauge into my 1.6 NA/TD car.
EXTREMELY fast response.
http://cgi.ebay.com/ebaymotors/DIGITAL-EGT-THERMOMETER-PYROMETER-W-PROBE-NPT-Blue-/200512513757?pt=Motors_Car_Truck_Parts_Accessories&hash=item2eaf7a26dd#ht_1711wt_1165
That's the same gauge I was planning on buying... Any way to make a video of temps climbing while you're at WOT?
Reply #65June 25, 2011, 03:13:20 pm
Mark(The Miser)UK
  • 1557
« Reply #65 on: June 25, 2011, 03:13:20 pm »
Do they make EGT probes smaller than 1/8 NPT? Less mass = faster response.  Something like 10- 32 or 10- 24 would have much less mass. Can you get probes in those sizes?
Many years agoI worked in a coal research establishment and one of my tasks was making up platinum/platinum-rhodium thermocouples up from fine wire, and ceramic sheathing. The fine wire would take the heat, as it needed oxy acetalene to fuse the wires togeather, but I'm not sure if  you could callibrate the basic gauge meaningfully...
Mark-The-Miser-UK
Reply #66June 25, 2011, 07:12:48 pm
JGWarner
  • 77
« Reply #66 on: June 25, 2011, 07:12:48 pm »
Wish I could get one of these 3" gauges:
perhaps replace my gasser tach (which will no longer work with the diesel).
Reply #67June 25, 2011, 07:59:39 pm
vdubspeed
  • 191
« Reply #67 on: June 25, 2011, 07:59:39 pm »
When you say it has extremely fast response, what testing have you done?  Data points please.
Testing? Seriously....I'm not an engineer. I just build stuff in my garage. 16vT, 20vT, TDI, g60, TD currently a VR swap. Anyway...
What I mean by fast response is when I turn the key on...it's ambient temp(correct for cold engine), crank it up and response is fast. Rev it up and the numbers rise and fall FAST. Not 23 seconds...instantly. WOT pull will yield 1500 degrees and let off will pull it back to 700 in a second. So. 1500 to 700 in a second is pretty responsive if you ask me.
And the probe you show and say you like is identical to the one that came with my gauge.
Reply #68June 25, 2011, 08:01:23 pm
vdubspeed
  • 191
« Reply #68 on: June 25, 2011, 08:01:23 pm »
Yeah...I can make that happen. Tomorrow on the way home church I will make a video.
Reply #69June 26, 2011, 09:43:19 am
vdubspeed
  • 191
« Reply #69 on: June 26, 2011, 09:43:19 am »
Reply #70June 26, 2011, 08:17:44 pm
JGWarner
  • 77
« Reply #70 on: June 26, 2011, 08:17:44 pm »
Wow, that's responsive. And gorgeous GTI, I hope my Fox TD sounds half that good.
1500F seems high, no?
Reply #71June 27, 2011, 09:37:50 am
« Reply #71 on: June 27, 2011, 09:37:50 am »
Reply #72June 27, 2011, 09:30:44 pm
JGWarner
  • 77
« Reply #72 on: June 27, 2011, 09:30:44 pm »
Updates in the vortex thread. Set my IP lift timing.
EDIT: This is a METRIC dial indicator, and the black tabs are set at the factory max/min values.
I err'd on the advanced side. Thoughts?
« Last Edit: June 28, 2011, 02:16:57 pm by JGWarner »
Reply #73June 28, 2011, 05:41:24 am
« Reply #73 on: June 28, 2011, 05:41:24 am »
It should be between .037 and .043 ... I have no clue if you are way above or below. I would go with somewhere in the normal range.
Reply #74June 28, 2011, 01:45:55 pm
« Reply #74 on: June 28, 2011, 01:45:55 pm »
Guessing that is at about 1.03mm?  Should be fine!  You can tweak it a bit from there to find the happiest mileage, etc.
