Author Topic: Why i love AHU Jettas  (Read 5314 times)
February 10, 2011, 04:59:32 pm
  • 1739
« on: February 10, 2011, 04:59:32 pm »
Some of you may have heard me mention that i believe the best car VW ever made was 97-99 TDI Jetta. I have more proof why. I've been looking to buy another and one of my old customers [ a friend actually] asked if i wanted his for $500. He bought it from another customer whose Nissan Torrano Diesel i had converted to to VO and was the original owner. The only real issue with the car was that the odometer had stopped working some 80,000 kms before selling it with 220,000 on the clock-so about 300,000 [ he was traveling about 1500 kms a week] . My pal bought it and put another 150,000 kms when i got it last week. Driving it back from Ottawa i was a little  worried i would be white knuckling back home, but it easily got up to 135 kph with zero boost [ecu went into limp 5 minutes after i got it].
I did a compression test today- all 4 are at 400 psi ! Fixed a couple of lights, unstuck the passenger door,  replaced the vacuum hose from the inlet to the ECU and air filter etc. Now runs great, lots of power. I'm happier than ever.
Reply #1February 10, 2011, 05:10:14 pm
catlin_cava
  • 1954
Re: Why i love AHU Jettas
« Reply #1 on: February 10, 2011, 05:10:14 pm »
Awesome!!!! I would of loved a MK3 AHU if I could of found one in good shape
Catlin
2010 VW Golf City 2.0L "Hers"
Reply #2February 10, 2011, 07:14:34 pm
« Reply #2 on: February 10, 2011, 07:14:34 pm »
Tell me the cruise control works and I'll go buy a lottery ticket.
Tell me the cruise control and vacuum door locks work and I'll... nah... never gonna happen.   ;) ;D
Reply #3February 10, 2011, 07:36:19 pm
blackdogvan
  • 574
« Reply #3 on: February 10, 2011, 07:36:19 pm »
 ;D
1991 Vanagon 1.9 mTDI
Reply #4February 10, 2011, 07:49:59 pm
  • 1739
« Reply #4 on: February 10, 2011, 07:49:59 pm »
The only other thing that doesn't work is that the glove box latch is gone. I won't bother opening it until i have a replacement.
I forgot to mention the exhaust. Everything from the down pipe back was original. Muffler was broken at the weld, so i had to replace it[ $108]. Then i managed to braze where it was rotten at the weld at the rear of the cat. Then i covered the rot along the seam in the center pipe with 2 coke cans and 3 hose clamps.I liked that I had to do every level of repair to the exhaust.
The suspension is all tight. even the license plate lights work.
I replaced the battery in the remote, all central locks and alarm functions working. Coolant bottle is nice and pink.
and yes the cruise works...
Reply #5February 10, 2011, 07:50:52 pm
catlin_cava
  • 1954
« Reply #5 on: February 10, 2011, 07:50:52 pm »
I had that both worked...and THE AC!!!!! but the cam plate in the pump started to go and then we noticed the floor started to rot real bad... :'(
Catlin
Reply #6February 10, 2011, 07:52:22 pm
catlin_cava
  • 1954
« Reply #6 on: February 10, 2011, 07:52:22 pm »
I have a complete glve box door you can have(if its none airbag)
Catlin
Reply #7February 11, 2011, 05:42:50 am
  • 1739
« Reply #7 on: February 11, 2011, 05:42:50 am »
Thanks it has airbags
Oh and this car has gone the last 150,000 on VO ,more proof against those who says it's bad for the engine and pump
As a matter of fact between this car, my Transporter and my last 98 AHU , they have clocked 300,000 on VO
Reply #8February 11, 2011, 09:07:00 am
« Reply #8 on: February 11, 2011, 09:07:00 am »
yea, but im sure you start up, and shut down on diesel fuel..
or is it 100% veg all the time? do you run 2 tanks or one?
Reply #9February 11, 2011, 11:18:01 am
  • 1739
« Reply #9 on: February 11, 2011, 11:18:01 am »
Two tanks, seperate systems. Car was only switched when completely hot. I agree that a single tank and or VO/Fuel/additive blending may not allowed such a long life.
Reply #10February 11, 2011, 08:13:00 pm
« Reply #10 on: February 11, 2011, 08:13:00 pm »
2 tank systems are the only way that it can be done and have the engine live, that ive seen atleast..
Reply #11February 16, 2011, 05:50:04 am
Sandy
  • 31
« Reply #11 on: February 16, 2011, 05:50:04 am »
Gotta go south for the shell and build your own. Rust Check is your friend.
2  99 A3 JETTA WOLFSBURG'S
    (RUST FREE FROM FL)
98 JETTA TDI...BUILT NOT BOUGHT
    (RUST FREE FROM FL)
Reply #12February 16, 2011, 07:22:35 am
  • 1739
« Reply #12 on: February 16, 2011, 07:22:35 am »
That what i'm in the process of doing. Have a pal who lives between Montreal and Washington DC. He sees enough of them down there that he thinks he'll find something good for for me.
