Author Topic: 1991 Jetta GL Chest/Shoulder Belt Assembly Needed  (Read 3879 times)
February 09, 2011, 01:23:14 pm
ftm1776
  • 149
« on: February 09, 2011, 01:23:14 pm »
I need a 1991 Jetta GL Chest/Shoulder Belt Assembly. Driver's side.    NOT THE LAP BELT ASSEMBLY.
(Addendum: Although the lap belt clasp is attached to this assembly)
I need the one that goes from the center console reel, across the chest and shoulder, and buckles into a receptacle on the door. It must buckle in order to start the engine.
The VW part number (on the belt near the buckle) is 167880705B
Does anyone have this part for sale?? Cost??
Go here to see a photo: http://www.flickr.com/photos/25178436@N07/5432031078/in/photostream/
Thanks
Thomas
Vancouver,WA
« Last Edit: February 10, 2011, 06:16:58 am by ftm1776 »
Thomas, Original and sole owner since new:
1991 Jetta NA 1.6 diesel, Engine Code ME, 5 speed, AWY transmission, Hydraulic Lifters
293,000 miles
LOOKING FOR A GOOD VW DIESEL ENGINE BUILDER ON THE WEST COAST
Reply #1February 18, 2011, 03:59:51 pm
im_n2_vws
  • 23
Re: 1991 Jetta GL Chest/Shoulder Belt Assembly Needed
« Reply #1 on: February 18, 2011, 03:59:51 pm »
I think I might have a couple lying around. I'll have to check.
Danny
68 Beetle,69 type 3 squareback
92 Jetta GL 8v, 91 Jetta GL n/a diesel,91 Jetta GL Carat,88 Jetta GL parts car
70 railbuggy (woodsbuggy)
04 Chevy Silverado / 18' carhauler
Reply #2February 18, 2011, 06:58:07 pm
Dakotakid
  • 1240
« Reply #2 on: February 18, 2011, 06:58:07 pm »
Well, I know I have at least one of them. Probably two.
Hopefully, you can find one from someone else though. They both just happen to be in a place which is going to take some serious effort to get at them and will have to charge for my time.....that's all.
I, too, have thrown so many of these away over the years. Why do you want to keep this system of belts, anyway? You could convert to the less annoying type.
Let me know if you run out of alternatives.
Reply #3February 20, 2011, 10:05:02 am
ftm1776
  • 149
« Reply #3 on: February 20, 2011, 10:05:02 am »
Danny,
Let me know what you find.
I need the latch/retractor assembly for the driver's side. The one near the hand brake lever.
Thanks Thomas
DakotaKid,
What other belt system is there??
Where can I go to take a look???
Can you suggest a link that I can go to??
Thanks, Thomas
293,000 miles
Reply #4February 20, 2011, 12:52:49 pm
Dakotakid
  • 1240
« Reply #4 on: February 20, 2011, 12:52:49 pm »
I meant by simply installing a standard belt out of an earlier Jetta or Golf. Where there would only be one clip/one long belt.
Your ignition interlock could be dealt with by wiring modification. It can all be done if you want to get away from the two belt system....that's all.
