Author Topic: ID these Pistons!!!???  (Read 8058 times)
February 08, 2011, 08:54:59 am
blackdogvan
  • 574
« on: February 08, 2011, 08:54:59 am »
Anyone know who what where how when on these pistons? Nural? Prothe? VAG? Something else? Pretty sure they aren't Prothe as the oil scraper groove isn't notched on either side of the pin as i've seen in other images of those pistons. Is the yellow discoloration between the rings normal?
From an engine that slurped oil & hydrolocked.
Thanks for the help in advance!
1991 Vanagon 1.9 mTDI
Reply #1February 09, 2011, 06:33:41 am
410
  • 581
Re: ID these Pistons!!!???
« Reply #1 on: February 09, 2011, 06:33:41 am »
They are not prothe pistons.  The prothe pistons have no support for the oil ring above the notches on each side of the wrist pin.  I don't know what they are though.
Reply #2February 09, 2011, 11:08:42 am
blackdogvan
  • 574
« Reply #2 on: February 09, 2011, 11:08:42 am »
I pulled the rod off yesterday, they are indeed Nural ALH +.5mm. Very nice.
Reply #3February 09, 2011, 07:08:55 pm
410
  • 581
« Reply #3 on: February 09, 2011, 07:08:55 pm »
Sweet!  That rod is some bent!
Reply #4February 09, 2011, 11:24:55 pm
dankcorey22
  • 379
    Cummins!
    • Anything that runs
« Reply #4 on: February 09, 2011, 11:24:55 pm »
what do you mean prothe pistons dont have support for the oil ring? i didnt notice a difference between the stock pistons and his pistons... and again i could be wrong
MY CARs-BLACK 99.5 Jetta TDI 5 speed 93,000- DC Stage 2 Clutch Kit 14Lb FW, Afe air intake box, 2.5" DP, 11mm IP, 2.5" stright piped, boost gauge, PP764, RC5 (WOW), 3-Bar, McNally EGT/Boost, 17/22, Race Pipe, EGR Cooler Delete, PD lift pump, R32 MAF housing,FMIC
1983 VW Jetta 1.6 turbo fuel mods
Reply #5February 10, 2011, 06:09:01 am
410
  • 581
« Reply #5 on: February 10, 2011, 06:09:01 am »
[/quote]
[/quote]
I bought a tdi piston set from prothe a few years back.  I'm still running them so they can't be that bad but go to his website and look at the second picture in the listing for his pistons.  The notch cast into the piston goes right into the oil ring groove.  No support for the oil ring in four places on the piston.  Then look at a good piston to see the difference.
Reply #6February 10, 2011, 09:30:52 am
dankcorey22
  • 379
    Cummins!
« Reply #6 on: February 10, 2011, 09:30:52 am »
[/quote]
[/quote]
Oh yeah i see it now. does it make that big of a differents?
Reply #7February 10, 2011, 11:30:22 am
blackdogvan
  • 574
« Reply #7 on: February 10, 2011, 11:30:22 am »
Its hard to say considering its just the scraper.
Reply #8February 10, 2011, 01:20:03 pm
dankcorey22
  • 379
    Cummins!
« Reply #8 on: February 10, 2011, 01:20:03 pm »
Their good looking pistons tho. Im goin to use it in my rebuild. i just dont really trust those rings.
Reply #9February 10, 2011, 02:11:00 pm
blackdogvan
  • 574
« Reply #9 on: February 10, 2011, 02:11:00 pm »
Only a few hundred more for Mike W  out of the vendors section. I'm not sure the prothe have the crown oil cooling btw.
Reply #10February 10, 2011, 08:57:21 pm
410
  • 581
« Reply #10 on: February 10, 2011, 08:57:21 pm »
Judging from the picture, the piston has more machined surface around the wrist pin compared to prothes.  I'm sure the extra money you pay for nural pistons is worth it.  I'd install a used set of nural pistons over new prothe pistons especially after trying the prothe ones.  I am definitely not a fan of prothes rings.  They seem to take forever to seat.  Awesome score on the pistons Blackdogvan.
Reply #11February 10, 2011, 09:29:30 pm
dankcorey22
  • 379
    Cummins!
« Reply #11 on: February 10, 2011, 09:29:30 pm »
the valve cups on the pistons are different also the nural ones has an open cup while the prothe ones have an enclosed valve cup
Reply #12February 17, 2011, 06:07:45 am
myke_w
  • 1099
« Reply #12 on: February 17, 2011, 06:07:45 am »
The pistons in question appear to be the Oil Galley Crown style pistons from the European ASV TDI.
They look different from the Nurals I sell in the markings on the crown, they may just be an older version.
The Prothe pistons pictured further down are ALH style, as mentioned they lack any oil ring support which would worry me.
